GWR Class 769 information. (Units no longer with GWR - Off Lease March 23)
Deepgreen
12 Jun 2013
Gomshall, Surrey
Those plastic covers on the lower part of the rail are for a separate purpose, they’re to indicate that a short circuiting device must not be used on that length of track.
There are some yellow plastic kickboards around though, they do exist.
Yes, indeed and there is perhaps a certain irony in this shot of mine! However, the fact that juice rails CAN be coated in plastic for the reason you describe surely shows that the process is also feasible for accidental contact reduction?
Benjwri
16 Jan 2022
Bath
Makes a lot of sense. 14 3-car 165s maintain the timetable on the North Downs, Basingstoke, Henley and Bourne End routes. Hopefully the 2018 timetable and running times can be restored on the North Downs Line.
Except for the West, where without the Turbo cascade we will be forced to suffer the continual short forming and overcrowding for the foreseeable future.
Speaking of the Turbos there's also the question of if any solution will be thought up for them. The standard response to criticism of the overcrowding has always been the 769s will give the issue with more turbos, but now this is not the case sure a solution needs to be thought up? It won't be long till the maintenance issues get to the point services are having to be cancelled.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Likely to go to Long Marston I’d have thought (to join their already sheeted over classmates) until Porterbrook decides what to do with them. However, with the railway in its current state, i don’t think it would be much of a surprise if they did make the trip to Newport.
Well, I am saddened by; a) the fact that we won't be getting 'new' trains on my line in the foreseeabe future, and b) that, despite claims of useful knowledge gained, such a long time and large amount of money has been wasted/spent on this project (notwithstanding the source of that money), both of which could have been used for a more fruitful outcome for passengers. It appears that the dignitaries' return run from Reading a few weeks back may well have been a requiem after all. So, we are stuck with the 165s, which, despite a superficial redecoration inside, are inadequate and which GWR seem to be treating with disdain, as they have decided not to label the first class accommodation in any way before putting them back into service, while still happliy charging passengers first class fares to sit in unmarked and frankly still pretty grim so-called first class accommodation. Very poor.
No, only since March 2020. The idea was a reasonable one initially but once they didn't work, and it was obvious that demand would never justify the use of the units, then it has been a waste of money.
Demand on Gatwick runs still often justifies the use of four car trains on the NDL. Certainly recent outings of two car 165s on the line have been ill-received!
Benjwri
16 Jan 2022
Bath
As we have learnt over the last few years in the west, just because demand justifies it, doesn't mean you will get it. Short forming is very quickly becoming the norm, and the Cardiff to Portsmouth route, which is longer and very often very busy is a prime example of a service which shouldn't be short formed but often is.
fgwrich
15 Apr 2009
Hampshire
It wouldn't surprise me if this becomes the latter. The Turbo's haven't been the most reliable since their move westwards, and with the HSTs going, it will be a case of sweating the assets even more than now (which is already pretty well stretched). I can only hope the long mooted suggestion of 158s from Wales does eventually happen, it will at least take some of the pressure off the fleets and allow for greater maintenance / additional coach lengths etc.
Bristol
As predicted, now confirmed cancelled from GWR on another forum:
"As it's now been announced on our Management briefing, I can confirm that the DfT have cancelled the lease for the 19 class 769/9 units as of April 23. The units will return to Porterbrook."
Has there been any indication of anything specific that caused the dft to pull the plug?
Normally I'd say nows the time to get on the phone with Stadler and order Flirts instead but I have a hard time seeing the money for that coming forth.
Evelynm
10 Sep 2021
Truro
Complete waste of time, money and resources then. Not exactly breaking news, but something that has been predicted for a while now.
Someone said on here a year or so ago that these units would never enter service with GWR. All the people who dismissed him have gone very quiet
The end of the lease being April 2023 was mentioned upthread as appearing to have made it an easy decision.
Yes, particularly given the lines on which the 769s were to be used on aren't the greatest money spinners in the area.
fgwrich
15 Apr 2009
Hampshire
Just simply sticking up the wires to Basingstoke (from Southcote) and along from Didcot to Oxford / Banbury would solve some of the problems. The North Downs is the harder one.
But I don’t buy the argument about the lines that the 769s were destined for not being great money spinners - Reading Basing is, and will always be a very busy commuting route. I’ve used it in the evening peak for a few trips recently and it is back to how busy it was in 2019, not helped by having a few 2 cars turn up on it of late. And that’s with the more spread out services.
contrex
19 May 2009
St Werburghs, Bristol
Indeed - in the SR types (Class 20x) the effect was most noticeable if you were sitting at the non-driving end of the power car, where the diesel was still audible but didn't drown out the traction motors directly beneath you. (Unlike SR straight electrics of the period, the traction bogie was at the inner end of the power car - presumably for reasons of weight distribution)
I can still remember after I 'emigrated' from SR land to GWR land as a teenager, being at Bath Spa and my train back to Bristol was a DEMU on an inter-regional service. The traction motors sounded (as they would) exactly like an EPB. Made me feel right at home. Even now, 50 years later, for me a rail line looks naked without a conductor rail.
Techniquest
19 Jun 2005
Nowhere Heath
A real shame, I was looking forward to trying them out soon. I guess it means I've technically 'cleared' GWR now for sure, which I'm pleased about as it means I don't have multiple trips to the Thames Valley coming up.
Great, another railway waste!
Anyone for a load of lightly used MAN D2876’s?
While the costs and leasing of the conversion of the units may not have come from the farepayer, the infrastructure improvements made for these will. Hopefully, they will eventually be used by 387s etc but until then, it’s another rather large waste of time and money.
The level of waste will depend on what happens next.
If they sell everything off cheap then yes, wasted money
If they reinstall it in something more modern like a class 379 (and it actually works) then less of a waste.
For clarity, I have no idea what will happen to the unused diesel generators, (or the 379s) although that is for a different speculative thread.
One thing appears clear, without turbos transferred from Thames Valley and North Downs, I have no idea how GWR will solve the short formed trains crisis in the west.
fgwrich
15 Apr 2009
Hampshire
Regardless of what can be re-used, there will still be a considerable amount of wastage in this. Compared to Northerns, or TfWs 769s, you have to remember that these had a full scale repaint, refurbishment, air cooling, External CCTV cameras & associated cab modifications, a bespoke bluetooth system for multiple working, cab modifications to appease the unions and all the associated kit to run them as Tri-Mode units over Northerns (which remains essentially a duel voltage unit) and TfWs more basic DC version. And that's all Porterbrook's money. Then there's the modifications made to Network Rail infrastructure, new signage, platform upgrades specifically for the 769s, signalling upgrades, platform extensions etc. All in all, while some components may be able to be used elsewhere, quite a bit of it wont. And we've already seen promise of re-using bits from the refurbished 442s in the rebuilt 458s, which look to face the same fate as the 442s did.
The GU's will likely find use elsewhere, but again the bespoke components designed to make it power the 769 wont be!
Clarence Yard
18 Dec 2014
Budget cuts - the savings that the DfT want off the TOCs budgets for 2023/4 are eye watering. They are looking for opportunities to bin stock at lease end dates and the GWR 769 were an easy hit.
If it wasn’t for these cuts, GWR would have probably been told to soldier on with them. As it is, they have now gone some way to meeting their 2023/4 cuts target.
FGW_DID
23 Jun 2011
81E
which forum was this announced on? Not had any management briefing at the depot!
WizCastro197
12 May 2022
Reigate
I do hope they now decide to refurbish the remaining 165s that operate along the North Downs, if we aren't getting any 'new' stock?
fgwrich
15 Apr 2009
Hampshire
They are... well, being refreshed. But as mentioned by @Clarence Yard in the Turbo refreshment thread, this is the third attempt to get the fleet refurbished and has to be done to the price (and parameters) set by the DfT.
I don’t know whether to be happy or sad, but at least the decision is made.
That's a long way away, well beyond the expected life of the 16xs (or the 769s). The size of the batteries required to power a 250 seat train over the unelectrified sections of the North Downs Line on a typical diagram would be very considerable, not to mention the cost and time penalties of the necessary charging point infrastructure.
This is not correct
The size of the batteries required to power a 250 seat train over the unelectrified section of the North Downs Line on a typical diagram would be rather smaller than the size of the engines and fuel tank required to power a 250 seat diesel train. (You’d need roughly 5-8 tonnes of battery pack).
There would be no cost or time penalties for the charging infrastructure. It’s already installed, between Reading and Wokingham, Aldershot South Junction and Shalford Junction, and Reigate to Gatwick.
As an added benefit, such a train would also be substantially quicker than the current stock, being lighter and more powerful. It would also be substantially cheaper than electrification. It is hard to think of a line more ideal for a battery train. What’s not to like?
DelW
15 Jan 2015
As an added benefit, such a train would also be substantially quicker than the current stock, being lighter and more powerful. It would also be substantially cheaper than electrification. It is hard to think of a line less ideal for a battery train. What’s not to like?
Shouldn't that be, "hard to think of a line more ideal for a battery train?
FenMan
13 Oct 2011
This is not correct
You're saying there would be sufficient recharging capability when running on 3rd rail and turning around at Gatwick and Reading.
I'm surprised.
But what would be the life-expectancy before the batteries fall short? 1yr, 10yrs or longer?
AM9
13 May 2014
St Albans
I'm surprised.
If they are sized correctly, there's no reason why they wouldn't give similar service to those in a regularly used car. It's the control of the charge/discharge cycle and the operating temperature of the battery that impacts most on their working life. We should presume that on a large installation that would have well-defined duty cycles, ant temperatures would be well known in the design phase.
That’s how I understand it too, should allow about 2% degradation each year, so normal practice is to start about 20-25% bigger battery, so still meeting requirements after 10 years.
Battery technology development is moving at a pace, so what is available in few years time might be stronger, smaller, or longer lasting
