Any other GWR passengers on here having problems with GWR Wi-Fi? I was on a GWR HST on Friday and there was no internet connection -exact same today (Monday). Same problem on both smart phone and tablet.
The wifi on GWR HSTs has never been brilliant, I've almost given up on it. I find it tells you there is an internet connection, but it's too weak to be usable. The wifi on the DMUs to which it has been fitted is far better.Any other GWR passengers on here having problems with GWR Wi-Fi? I was on a GWR HST on Friday and there was no internet connection -exact same today (Monday). Same problem on both smart phone and tablet.
No WiFi on GWR working for me on 29th July, but Facebook and Facebook Messenger for some reason, did work on all trains.
I did a few journeys in June. I gave up on it, as it was useless.Any other GWR passengers on here having problems with GWR Wi-Fi? I was on a GWR HST on Friday and there was no internet connection -exact same today (Monday). Same problem on both smart phone and tablet.
As a general rule I find it to be OK on Thames Turbos but barely usable on HSTs unless it's a very quiet train, which suggests there isn't enough capacity for all the passengers on a HST that would want to use it. But there are also fairly regular occasions where train doesn't seem busy but it just doesn't really work at all, so there's probably another regular fault there somewhere too.
GWR HST wi-fi is a waste of time, I've been told by GWR that there's barely any coverage in rural areas, which is about 80% of the journey from CDF to PAD. Well worth their exorbitant fares then :roll:
A post which sums up the approach of many railway staff to customer service, whatever is advertised over and above conveying you from A to B, you shouldn't expect it as you're not entitled to it, and if it's not there it's always someone else's fault.I didn't know the cost of your ticket entitled you to free Wifi. I thought it entitled you to a journey between two places.
The coverage is decent enough with the obvious proviso of rural areas having slighly patchy coverage due to national 4G infrastructure beyond GWR and indeed mobile operators' control in this NIMBY country. Also tunnels. I find it's worst in the Thames Valley, possibly due to local capacity vs demand from a highly populated area.
Also don't forget GWR use at least two, possibly three different wifi systems - the one on the 150s and 158s is not the same as the one on the HSTs for example.
All the HST Wifi is managed by an external company so chances are it's a problem at the contractor's end that will be solved in due course.
http://nomad-digital.com These are the HST wifi providers and in my experience, it's as much use as a chocolate fireguard.
