Is that not making good the crash damage that would have been left from the Class 710 crash earlier this year / late last year?I note that some work has been done to the buffer area on platform 2 at Enfield Town with some new ballast and similar. This looks like it was recent as The track on P2 has had evidence of train running in the last couple of days
Work begins on Saturday 11 June and at weekends throughout June and July. The work includes:
Work also continues on the Gospel Oak to Barking line throughout June and July . This work includes:
- Renewal of a crossing unit and a turnout unit at Seven Sisters, these are pieces of track that allow trains to move from one line to another
- Structure repairs to Seven Sisters Road (A503) will also be carried out during the closure.
- Renewal of wheel timbers that help keep the track in place
- Works to Upper Holloway footbridge
Does the track layout make that possible?I was surprised that London Overground hadn't inserted the calls at Cambridge Heath/London Fields onto the Chingford services to give those stations a service when the line towards Seven Sisters was closed. Would have reduced the need for replacement buses from Hackney [assuming they were running].
Yes, in that Chingford trains can cross north of Hackney Downs Station but no, in that the stop markers are on the slow lines north of Bethnal Green, so the relevant platforms are shut.Does the track layout make that possible?
The Block is actually Bethnal Green North Jn to Cheshunt / Enfield Town hence Cambridge Heath and London Fields are closed and trains via the Fast Lines only. Also a separate Liverpool Street 1 - 4 to Bethnal Green West Jn BlockI was surprised that London Overground hadn't inserted the calls at Cambridge Heath/London Fields onto the Chingford services to give those stations a service when the line towards Seven Sisters was closed. Would have reduced the need for replacement buses from Hackney [assuming they were running].
Replacement overhead wiring does make a bit of sense if the original wires is coming to the end of its design life, after-all Network Rail did do a rolling system of replacing the overheads on the mainline out of Liverpool Street & to Southend.
I wonder if it's to do with line speeds, as there's lower chance of stuff coming down at lower speeds, although the line is just as heavily used Some trains run via the Seven Sisters line to Edmonton Green then on to other destinations - (I've caught a train from Liverpool Street to King's Lynn via Seven Sisters many years ago). The newer Furrer+Frey (?sp.) kit finishes just after the Bethnal Green curve and the original 60's stuff continues on from Cambridge Heath (though for some reason, White Hart Lane has new OHLE just the length of the station) Newer 80's stuff is from Clapton Tunnel up the WAML through Tottenham Hale to Cheshunt, and it's a mix of old and new kit from there to Cambridge, despite high line speeds of 90 to 100I was surprised that London Overground hadn't inserted the calls at Cambridge Heath/London Fields onto the Chingford services to give those stations a service when the line towards Seven Sisters was closed. Would have reduced the need for replacement buses from Hackney [assuming they were running].
The Southbury loop is frequently used as an engineering work diversion, and peak time Hertford East trains go that way. It is mostly 50mph Hackney Downs-Bury Street Jn and 60 mph from there to Cheshunt, unless there's been significant change in recent years. Although it is only half a mile further than the Lea Valley route it takes about 10 minutes longer.I wonder if it's to do with line speeds, as there's lower chance of stuff coming down at lower speeds, although the line is just as heavily used Some trains run via the Seven Sisters line to Edmonton Green then on to other destinations - (I've caught a train from Liverpool Street to King's Lynn via Seven Sisters many years ago). The newer Furrer+Frey (?sp.) kit finishes just after the Bethnal Green curve and the original 60's stuff continues on from Cambridge Heath (though for some reason, White Hart Lane has new OHLE just the length of the station) Newer 80's stuff is from Clapton Tunnel up the WAML through Tottenham Hale to Cheshunt, and it's a mix of old and new kit from there to Cambridge, despite high line speeds of 90 to 100![]()
It's relatively common for weekday off peak trains to Cambridge/Stansted/Hertford to be diverted along the slow lines for a few hours. I've done it numerous times in recent months.Yep, I've seen it happen a couple times before. There is a connection between the "slow lines" towards Clapton at the northern end of Hackney Downs (https://www.opentraintimes.com/maps/signalling/ls_2), just means the Chingford trains get retimed to take into account the extra stops
Although looking at the Open Train Times Map, those stations are under T103 which explains the lack of service (as the lines are closed)
Thanks for letting me know... I never knew the top speed of the West Anglia line was 90... though with the hot weather, I'm sure the older knitting can start to sag... though I guess it's held up for years. The engineers at Seven Sisters could have been checking contact wire or registration arms or something else as part of maintenance. It's a few weekends they will be closing the line, some say it is to lengthen platforms to accommodate longer trains...The Southbury loop is frequently used as an engineering work diversion, and peak time Hertford East trains go that way. It is mostly 50mph Hackney Downs-Bury Street Jn and 60 mph from there to Cheshunt, unless there's been significant change in recent years. Although it is only half a mile further than the Lea Valley route it takes about 10 minutes longer.
There's no 100mph track on the Liverpool Street-Cambridge line, and only a few bits of 90mph, mainly north of Audley End.
North of Bishops Stortford was electrified in the 1980s so there's no legacy 1960s OHL there.
