Haywards Heath to Zone 1 Travel Card
KitKat79
20 Oct 2023
Northern Ireland
Hi
Please could someone help me.
I live in Northern Ireland and traveling over and staying in Haywards Heath.
Can I order the 1 day travel card that gets posted to you for Zones 1-6 and then pay the difference to travel from Haywards Heath into Zone 6?
How do I purchase the Haywards Heath to zone 6 part of my journey.
Thanks
James H
25 Jun 2014
Is your travel from Haywards Heath to London all on the same day, or over multiple days?
KitKat79
20 Oct 2023
Northern Ireland
It’s for one day and valid for zones 1-6
I thought Haywards Heath was Zone 6?
I’m traveling for one day into London and on the tube, then return to Haywards Heath the same day.
James H
25 Jun 2014
Haywards Heath is some way beyond the edge of Greater London, and beyond the Oyster/contactless zone
You can just turn up at Haywards Heath and buy one ticket that covers you for the trip into London and your travelcard for use in the zones - no advantage to booking in advance or having anything sent by post.
(assuming travel is before Jan 2024 when Day Travelcards may be abolished)
How early in the morning would you be leaving Haywards Heath? And would it be a weekday or weekend?
Mcr Warrior
8 Jan 2009
It's not, it's well outside of the London zones.
Are you starting your day's journey at Haywards Heath, and travelling into Central London, before returning, later the same day to Haywards Heath?
If so, what day of the week are you travelling, and what time are you planning on setting off from Haywards Heath?
On Saturdays/Sundays and Bank Holidays, a Super Off Peak Day Travelcard (route "Thameslink Only") can be had for just £16.40 and is valid within London zones 1-6 once you've got there on a Thameslink service from Haywards Heath.
James H
25 Jun 2014
In that case a Day Travelcard including travel from Haywards Heath to London and back, and unlimited travel in zones 1 to 6, is 25.80
Available on the day at that price, and will not sell out, so no advantage to prior purchase.
MrJeeves
28 Aug 2015
Burgess Hill
Thats correct.
Im travelling on a Thursday at around 11am then returning in the evening at about 9.30pm
In that case, you can turn up on the day at the station and buy your ticket from one of the two card-only machines outside, or two cash and card machines inside, or from the ticket office (if it's still open by the time you visit).
Often, London Zones 1-6 Travelcards will be on the first screen of the ticket machine, but sometimes these aren't the best value ones.
Instead you can press the "A-Z destinations" button and search for "London Tra" and the option for Zones 1-6 should be on the right hand side of the screen.
You can then press "cheapest ticket" at the bottom and it should select one for £25.50.
You can actually get a cheaper super off-peak travelcard for £25.50 that allows travel on both Thameslink and Southern up to Zone 6 (effectively East Croydon).
This is valid for trains arriving into London from 10:45am onwards, but (in a nutshell) you cannot use it to leave London back to Haywards Heath between 16:14 and 19:16.
I would personally recommend this one if you're not leaving until about 8:30pm (to arrive back to Haywards Heath at around 9:30pm) simply because it gives you more choices for services to and from Haywards Heath into London (the £25.80 one is Thameslink only).
I won't go into the conversation about whether "Thameslink only" and "Not Gatwick Express" is actually valid or enforceable. It's not worth a tourist worrying about.
It is worth mentioning the "Thameslink only" and "Not Gatwick Express" bits on the ticket only apply outside of Zones 1-6. For example, if you choose the Thameslink only ticket and want to go to London Victoria, you can take Thameslink to East Croydon (which is in Zone 5), then change for a Southern service to London Victoria.
Mcr Warrior
8 Jan 2009
As @MrJeeves has just noted, the Super Off Peak Day Travelcard (route "not Gatwick Express") at £25.50 slightly undercuts that, but the key thing is it can't be used for weekday return travel between 1615 and 1915.
Mcr Warrior
8 Jan 2009
Thank you so much for all your help.
It’s so confusing.
Not particularly. Basically the cheapo fares mentioned upthread are primarily intended to encourage passengers to use what are considered to be 'non peak' services.
Alex365Dash
2 Jul 2019
Brighton
A bit easier than the pain of typing on a S&B TVM is hitting the Travelcards button on the ticket machine then selecting London Travelcard Zones 1-6 from the list.
