trainmania100
Must be a common problem . Locomotives from Hornby with a working fan, making a loud unattractive squeeling noise.
Video from my 50 if anyone can hear it
youtube.com
Does anyone have a fix?
As bad as it sounds, I have put oil on the two gold pulleys which drive the shaft propelling the fan (and oil on the elastic which I'm sure will fail at some point), however some slight improvement the sound persists.
Without too much dissection it appears to be contact between the two gold pulleys with the band between them. Image attached.
Has anyone identified a fix? Thanks
12 October 2021
