How do you buy single tickets on a smart card?
Martin54321
4 Oct 2021
Reading
I'm starting a commute from Reading to King's Cross. On most days it makes no sense at all to buy a season ticket - it's better for me to buy a single from Reading to Zone 1 and then a Single from Zone 1 to Reading with a Network Railcard. I'd ideally like to buy it in advance at home and load it on to a smart card. However, on the GWR website I don't get the option to do that. I can buy a season ticket and put it on the smart card, but not a single.
Is it impossible to do this, or are GWR keeping it hidden to discourage people buying cheaper tickets on a smart card?
Martin
Is it actually going to be cheaper to use Contactless in this direction?
Is a mobile e-ticket for the Paddington to Reading section and Contactless on the underground possible? I think e-tickets for single fares rather than smartcards are probably the way they are taking future ticketing forward (but not on the underground).
sammyg901
24 Mar 2009
I just checked my Chiltern Railways app and it will let me load a Reading-Paddington single to my smart card no problem. Not a ticket to Z1 though
Martin54321
4 Oct 2021
Reading
Thanks. If I use a barcode ticket then I can't buy a Reading to Zone 1, only Reading to Paddington, and then tap my debit card for tube travel. An off peak return with a network rail card cost £14.45, plus the £4.80 for the return on the tube. A travelcard costs £17.60 - £1.65 less. But you can't get a travelcard on a barcode ticket.
I'll try a chiltern smartcard instead of a GWR one - it sounds more user friendly.
Martin
Wallsendmag
11 Dec 2014
Wallsend or somewhere in GB
Martin
They all work exatly the same
Haywain
3 Feb 2013
The issue is not the smartcard but the website offering smartcard fulfilment. If you buy from another retailer who does offer smartcard fulfilment you should still be able to use your GWR smartcard.
island
30 Dec 2010
I believe zone U* tickets can only be issued onto traditional paper tickets (and not PRT, smartcards, or barcoded ticket)s), but I am open to correction.
Haywain
3 Feb 2013
Possibly on smartcards if the price setting TOC has set it up, but not the others. Travelcards should be reasonably easily available on smartcards.
mattdickinson
14 Nov 2010
Uxbridge
The Chiltern app only allows fulfillment to the Chiltern smart card
kieron
22 Mar 2012
Connah's Quay
Off topic, but thanks OP for raising this question. I've just discovered zone 1 tickets are a thing so you've saved me 70p vs a day travelcard.
If you're looking at any anytime day return from Reading to Zone 1, you could save a few more pounds by buying a return to West Drayton and a separate Zone 1-6 travelcard (costing £43.40 in total). This combination is valid on non-stop trains as one ticket is a travelcard, but it isn't valid via Ascot.
A ticket to "boundary zone 6" would cost 20p more than one to West Drayton, but you could buy a "change of route excess" to turn it into a "via Ascot" ticket for an extra £1.70 per direction, if you needed to. I don't think you can do any of this on-line, though.
This sort of thing is be less useful off peak, though, because of railcards.
Martin54321
4 Oct 2021
Reading
Thanks for the heads up on Chiltern being better than GWR for selling tickets that can be loaded on to a smartcard.
They still have some puzzling restrictions. For example, I can load a Standard Reading to London travelcard on to a smartcard, but not an Off Peak Reading to London travelcard.
Also, even though I can load that standard travelcard (which includes the tube), I can't load a single which includes the tube. Chiltern is a step forward, but the two best value fares still remain unavailable for smartcard use, despite it being technically possible.
Wallsendmag
11 Dec 2014
Each TOC is different, we for example have only enabled seasons and day Travelcards for fulfiment to Smartcards.
mattdickinson
14 Nov 2010
Uxbridge
I attempted to buy 2 tickets on the Chiltern app using my Two Together railcard. It asked for two smartcard numbers. It successfully fulfilled to my girlfriend's smartcard, but wasn't visible to load on to mine. I'm just waiting to hear what their reply is to my e-mail.
alex8339
21 Sep 2021
Reading
This doesn't work for me as I have a 26-30 railcard. West Drayton + TC Z1-6 totals £37.30, compared to £37.05 for a U1-2. Though there's still a 45p saving if I needed a travelcard.
However, I have just discovered an any permitted Reading to Clapham Junction anytime day return is just £33.95. Think it's fine to break the journey at Victoria to spend a day in the office before continuing onto Clapham to see friends in the evening, but have no idea whether it's valid as my regular to St James' Park.
lancededcena
28 Aug 2013
Colchester, Essex
GA allows single tickets to be loaded to their smartcard from their app or on a TVM with a railcard (did it a few days ago).
This is what it shows on the GA app and NR smart card app (obviously expired):
