How to keep a plastic travel pass in mint condition
gray1404
3 Mar 2014
Merseyside
I am a holder of a England national concessionary travel scheme pass which allows free travel on trains anywhere in Merseyside (and all of Merseyrail). It is a plastic card and the one I have is now 2 year 4 months old. I have another 8 months validity left on it.
The problem I am having is that the information on the card is starting to fade. Some of the print has come off the card and onto the plastic. Other parts of just faded totally. I keep it in a railcard plastic kind of thing, I got a railcard holder and cut off one section so I can keep it in my wallet and use it as a flash pass.
It is still just about readable and I have not had any problems with it being accepted or any comments given. I have not had any comments on buses in other areas either where you often have to show the pass rather then scan it. But it is certainly not mint anymore. Hopefully I can use this one without problem until it runs out in April. When I get my new one though, is there any way I can store it where by it won't fade like this?
I do need to have it in my wallet at all times as I use it most days to make some sort of journey.
Merseysider
Fares Advisor
22 Jan 2014
Try to keep it in a separate pocket at all times from other heavy items like phones/wallets/keys etc which can rub against the card holder
PeterC
29 Sep 2014
It's easy in the Home Counties, you just use a free Oyster wallet.
gray1404
3 Mar 2014
Merseyside
I have an oyster wallet but isn't this the same as a railcard holder, that I am currently using? I'd have the same problem with the print rubbing off the card onto the plastic of the railcard holder.
Flying Snail
12 Dec 2006
It is probably a slight amount of movement between the card and the plastic of the wallet causing friction damage, if you do not need to remove the card for use I'd suggest either getting a wallet that grips tighter or stuffing some other cards in behind it to make it tighter.
You could get a smartphone screen protector, cut it to size and stick it to the card.
BlueFox
20 May 2013
Carlisle
Is it credit card sized?
I had a supermarket loyalty card where the barcode was starting to fade, as it had been rubbed off. It must have been a common problem, because one day when I used it the check out operator put it in a clear plastic sleeve to protect it.
It just stays in the sleeve all the time, and it's a tight fit so there's no chance of anything rubbing off.
These ones on eBay look similar: http://rover.ebay.com/rover/1/710-5...ep_vectorid=229508&kwid=902099&mtid=824&kw=lg
gray1404
3 Mar 2014
Merseyside
Thanks everyone. I think a combo of a screen protector plus card wallet that allows for no movement is best. I wonder if banks still offer card holders? I noticed that even a tight fitting card wallet can loose up over time.
gray1404
3 Mar 2014
Merseyside
I got totally caught out with my travel pass this week and it ended up costing me. The pass I was 2 years 6 months old. It had another 6 months validity on it. However, a week ago it stopped working on the card readers. I tried on a couple different buses and the drivers were very nice about it.
I phoned Merseytravel and on the phone the chap I spoke to ask me to take the card out of any wallet it might be in and inspect for damage. I could not find any. He asked if I could take it to a Merseytravel centre, my nearest being in Bootle and if it was a question of it being faulty it would be replaced free of charge. He explained that they charge for loss or damaged passes, but it if is faulty no charge would apply.
I went to Bootle on Friday. The lady there did started out by being determined to find out why it wasn't working. In other words she didn't start by testing it on the card reader they have. She took it out of my plastic wallet and bent it around a little bit (I was surprised by this action as I was expecting it to be looked at rather then being put under any strain) and then disclosed there was a crack, which was in the very top left hand side by the red rose.
She said "it looks like it has been sat on." "have you had it in your back pocket?" I explained that I have only ever had it in my card holder which I keep in my wallet. I explained that I have taken great care of it and I believe the problem being due to reasonable wear and tear. No amount of reasoning with her made any difference. I ended up paying the £10 for a replacement so I didn't want to get stung with any bus or train fares in the mean time as she told me I would have to pay.
I asked for a comments form as I wanted to express my concerns. She gave me one along with a receipt. She said that she would put a note on my customer profile explaining that I had been issued with a comments form and that I was unhappy about paying the £10 charge due to the reasons stated above. I took a photo of my old pass as well as she insisted that I could not keep this. She then put it through a shredder. I was disappointed with that because it means this can no longer be considered along with my complaint.
I looked up Merseytravel's complaints procedure online and I saw it was possible to complain by phone if you call customer services. I phoned up and had a difficult phone call with a chap who was convinced that a complaint had gone in already based on the note on the system (above). Whenever I tried to explain that was only a note saying I had been issued with a comments form he kept cutting in saying "I don't know I wasn't there and I wasn't the one you spoke to."
In the end I won him round by saying I was concerned that the full information had not been captured and he then offered to submit another complaint for me. I hope to goodness he has actually raised a complaint (he said it needs to go to the "comments team") and not just added to some notes on my customer profile. I explained to him what had happened and he ended the call assuring me in a very nice was: "yes, I understand you feel like you have been hit twice. A faulty pass then being hit with a £10 charge." I made it clear to him that I understand if I had been careless with it and damaged it myself then I would of course except to pay. He assured me "don't worry, I know what to put."
I do feel let down my Merseytravel here. They have not allowed for wear and tear of the pass and I am unhappy as to the way they physically handled my pass.
Sadly the new pass I have been issued with now expires in April 2022. I am of course highly concerned it will not last this long - if not for it cracking but by the details fadin as per my opening post. I do not think the quality of the new pass is the best. Some of the text on the back of the pass is readable but could be much more clear. I fear that they actually have no intensive to issue high quality passes to people if they can extract £10 a time for a new one. This might also explain why they are issuing them for longer periods now. It really is as if they are extracting money from the most vulnerable people in society.
It will be interesting to see what they respond. However, given the militant response I have had up to now I am highly doubtful of anything positive.
For now, I have placed my pass in the plastic card holder. However, I was wondering if a smart phone protector (as suggested above) might help or indeed could this make it worse? I think you can get these from the pound stores.
