How to Reskin a train on MSTS
12 Nov 2008
Hi i want to reskin some of my favorite trains on MSTS but i dont know how. can anyone help me?
Thank You
Victorialine67
EirikhO
11 Jan 2009
You need a tool to convert the ACE files to another image file format, i.e. BMP. You can use Tgatool2 to do this.
[Download link Tgatool2]
I suppose you know how to do the rest, but if not, here goes:
After installing Tgatool2, do File -> Load, then select the file you wich to edit (MSTS folder/TRAINS/trainset/[train]/[file name].ACE). After opening the file, press Export-> BMP, and select where you want to place the bmp file, which will be the file you'll edit. Edit the BMP file with a suitable program (MS Paint works fine), then open Tgatool2 again, open the BMP file, export it to ACE (not sure which one tho), replace your file with the original, or make a new file name, but that requires you to edit some other files aswell (those files defining which texture that should be used), but i don't know which these are.
Hope that helps.
12 Nov 2008
Thank you ever so much mate ill let you know when my re-skins are avalible to download
