Given that HS2 is going to be building be stations at Birmingham, Leeds, Manchester, Crewe, etc. there's an argument that this will, by removing long distance services from the existing platforms, provide space for more services to run to these stations.
As such, and also bearing in mind that the long distance services are also being removed from the classic network, how would you use this freed up capacity to improve rail services?
It should also be noted that, because some of the big ticket costs have already been done in the firm of improved capacity at the major station, the overall costs of schemes which would require additional improvements would fall. This would mean that the cost to benefit ratio would likely be better and in some cases a lot better.
In answering this question there will be some that will need to stop thinking HS2 is of no use to me (as I don't want to go to London) and start thinking how can I use HS2 to improve the rest of the rail network for me (as I do want to travel into those cities from the area around them).
Edit: title changed to include for discussing improvements after the opening of NPR, although with NPR in brackets to indicate its less confirmed status.
