I'm going to go to every tram stop in Manchester
Brubulus
13 Oct 2022
Cambridge
I have plans to go to every tram stop in Manchester, in less than the current record. I am planning to do it public transport only.
I am going to do Airport and East Didsbury first. However I am not sure about what to do from there to do it most efficiently. Altrincham and Bury seem to be annoying to get to from the other lines, without doubling back.
Any advice?
Ken H
11 Nov 2018
N Yorks
I have plans to go to every tram stop in Manchester, in less than the current record. I am planning to do it public transport only. I am going to do Airport and East Didsbury first. However I am not sure about what to do from there to do it most efficiently. Altrichnam and Bury seem to be annoying to get to from the other lines, without double backing. Any advice?
Frequent bury - Rochdale buses if that helps. Is there not an airport - Altrincham bus?
Mcr Warrior
8 Jan 2009
Probably be inclined to start/finish at Manchester Airport and Rochdale Town Centre (or vice-versa) as they are the longest sections of line that you need to traverse before interchanging for other parts of the Metrolink network.
507 001
3 Dec 2008
Huyton
Don’t forget that the temporary timetable in place at the moment my make things more difficult.
py_megapixel
5 Nov 2018
Northern England
Airport to Altrincham is only 25 minutes on the bus but time it carefully as the bus only runs hourly (route 288). There's also the option of doubling back to Wythenshawe and using bus 11 which is more frequent.
Mcr Warrior
8 Jan 2009
Reckon that using other modes of public transport, such as a bus, to interlink between outlying Metrolink terminii, for example from Manchester Airport to Altrincham, is perhaps not in the truest spirit of the challenge, but this is just my personal opinion.
61653 HTAFC
18 Dec 2012
Assuming "Tube Challenge" rules, this would be acceptable. Doing it by Metrolink alone would take significantly longer and include a lot of "dead" mileage due to the double-backs.
Ken H
11 Nov 2018
N Yorks
Rochdale & Altrincham are served by trains from central Manchester...
daodao
6 Feb 2016
Dunham/Bowdon
I have plans to go to every tram stop in Manchester, in less than the current record. I am planning to do it public transport only. I am going to do Airport and East Didsbury first. However I am not sure about what to do from there to do it most efficiently. Altrincham and Bury seem to be annoying to get to from the other lines, without double backing. Any advice?
Some comments that may be useful:
There are good bus links between some of the outer termini:
  • Bury to Rochdale - routes 467/468/471 (frequent)
  • Eccles to Trafford Centre - routes 20/21/22/52/100 (frequent)
There is a good frequent bus service between Ashton and Oldham (409) which could be used with a double back on the Rochdale line between Oldham and Monsall. Alternatively, one could terminate the trip at Ashton, but that means using buses to get from the Airport line to Altrincham.
The Airport line is very long and slow, as it weaves around Wythenshawe, so one wouldn't want to double back all the way on it, and there are frequent fast trains between the Airport and Piccadilly for a return to the centre of the Metrolink network. There is a large Metrolink car park at East Didsbury, if starting the journey there. If starting at East Didsbury, one can turn back at Firswood to cover the Airport line.
Bus links to/from Altrincham are slow and infrequent, so it would probably be best to end one's journey there. There is a bus between Altrincham and the Airport taking 25 minutes (route 288), and but it is only hourly, so if using it one would need to plan one's schedule carefully. There are more frequent buses from Southmoor Road (where Metrolink crosses the A560) to Altrincham, but Metrolink doesn't stop that close to this junction.
Don't forget that there are several intermediate stops on the routes across central Manchester, one or two of which could be inadvertently overlooked.
py_megapixel
5 Nov 2018
Northern England
By not doing so, you would massively extend the time taken, as there are essentially no opportunities to change between lines other than near the city centre (I think the furthest out is St Werburgh's Road, unless you count walking from MediaCity to Imperial War Museum).
Brubulus
13 Oct 2022
Cambridge
I just finished successfully. Used tube challenge rules but decided to double back at Altrichnam. Due to football, there was severe traffic on the East Manchester line, which slowed me down , along with failing to run between trafford centre bus and tram stations. There were also problems on the Rochdale line. In total it took 7h 20 minutes(Constant from 0841 to 1601). St Peters Square - Airport. (Rail from Airport to East Didsbury) East Didsbury to Trafford Bar. Trafford Bar to Altrincham. Altrincham to Cornbrook. Cornbrook to Eccles via MediaCity UK. Bus (Eccles to Trafford Centre) Trafford Centre to Cornbrook. Cornbrook to Rochdale Town centre. Bus (Rochdale to Bury) Bury to Abraham Moss. Abraham Moss to Ashton. With the service alterations this did get all city centre stations.
Altrichnam trains are hourly and actually slower than metrolink in many cases as they go via Stockport
Ken H
11 Nov 2018
N Yorks
Nice one.
william.martin
18 Oct 2022
Telford
Well done!
scrapy
15 Dec 2008
As are Manchester Airport, East Didsbury, Eccles and Ashton. If you time it right as Eccles and Ashton only usually hourly.
If you time it right you may be able to start at Barlow Moor Road, tram to the airport, then train to East Didsbury and head back to Manchester from there. In the morning peak is also possible to get a train direct from Eccles to Rochdale. (Before December 10th)
jrail1992
9 May 2012
Wigan
Nice work, did you beat the previous record then?
