Lancaster Green Ayre Railway Station
21 Feb 2018
Blinkbonny
16 Mar 2018
Excellent stuff. As a young man I worked in a youth club set in the old Green Ayre engine shed.
JBuchananGB
30 Jan 2017
Southport
On a recent visit to Lancaster I walked along part of the former trackbed of the line which linked Lancaster Castle to Green Ayre. I noticed that a road bridge was standing on the stanchions of the former railway line across the river.
It is interesting that when the line from Wennington to Lancaster closed, the train service from Leeds to Lancaster continued, albeit via Carnforth, and indeed still runs today, although some services start/end at Skipton at one end and at Morecambe at the other end.
Senex
1 Apr 2014
York
With hindsight, I wonder if the line to be kept should have been Wennington - Green Ayre - Lancaster Castle rather than the Joint Line to Carnforth.
Dr Hoo
10 Nov 2015
Hope Valley
I suspect that the triangular junction with the Furness line at Carnforth (for freight) was the major reason.
Senex
1 Apr 2014
York
Though that connection (Carnforth East Jn to F&M Jn) lasted only till 1989.
randyrippley
21 Feb 2016
Its the same bridge (i.e. the third rail bridge) with concrete cantilevers to widen the bridge deck. Not just the stanchions
randyrippley
21 Feb 2016
That's what BR wanted to do, but the County Council wanted Greyhound Bridge for road use and financial inducements made sure the council got its way
randyrippley
21 Feb 2016
I don't believe that was a consideration. The Furness & Midland was originally slated for closure, then the decision changed
Dr Hoo
10 Nov 2015
Hope Valley
Noting that the 'Beeching Report' explicitly showed withdrawal of all passenger services on the more southerly route, listed Green Ayre station for closure (along with the duplicate route to Morecambe via the low level river bridge and Scale Hall) and showed retention of the Carnforth line (albeit with local services withdrawn), do you have a source for your claim?
randyrippley
21 Feb 2016
Nothing I can prove. Its verbal information from city and county councillors who were around at the time.
As I understand it the Beeching Report was subject to political meddling prior to publication
70014IronDuke
13 Jun 2015
Why?
Don't get me wrong, I would have liked to see both routes kept.
But I'd have liked to see Carnforth WCML platforms also kept. Once they had gone, the case for keeping the Midland route into Lancaster Green Ayre gets stronger, IMHO. But I suspect the argument at the time stressed the possibility of changing at Carnforth for servicies north.
Merle Haggard
20 Oct 2019
Northampton
I bunked Green Ayre shed once (their 'Jinties' were elusive). It had a very unusual track layout; the arrival/departure line ran past the shed onto a turntable. All access to the shed was by means of the 'table, which was outside the shed, and locos reversed direction on the table (obviously, after it had been turned to the required road) which was at the end of the site.
It had the major flaw that, if the table broke down, engines were trapped inside and there was also little space to stable arriving engines. Of course, the first snag also applies to roundhouses, which the Midland seemed to favour.
It's not clear whether the building still exists - does anyone know? Curiously, a little further North at Carnforth both the Midland Railway roundhouse building and the LMS shed (built to replace the previous 3 sheds including the Midland one) still survive.
Senex
1 Apr 2014
York
Why?
Though Carnforth never had the choice of reasonably fast WCML services offered at Lancaster, so wan't really such a good place to change, I'd have thought.
randyrippley
21 Feb 2016
Part of the shed walls are supposedly retained in the external walls of Sainsburys, but I've never managed to identify where. It all looks like new build to me (though with areas of recycled stone)
70014IronDuke
13 Jun 2015
Well, OK, but then you had to faff around getting up to Castle from Green Ayre if you took the southern route. (I suppose you could have gone via Clapham, Kirkby Lonsdale and Tebay before the closure of that route. Not sure when that was.)
Whatever, I'm still intrigued as to why you suggest keeping the Green Ayre line might have been the better option.
Senex
1 Apr 2014
York
What about the regular electric trains between Green Ayre and Castle? And what I was thinking about was keeping Wennington to Castle, plus (as was done) the Castle to Morecambe line, thus providing a simple change just at Castle. (The Ingleton route would have been nice, but what long-distance trains were ever going to stop at Low Gill or Tebay?)
70014IronDuke
13 Jun 2015
Was there a direct service from Wennington to Castle? I didn't know there was a link. I thought you had to go into Green Ayre and reverse, or change trains.
If so, that's kind of different, of course. It would, presumably, have been quite quite a lot faster to Lancaster to boot. It does make you wonder why they chose the northern link, I agree.
That Lune Valley, through Claughton, is a lovely, relatively unknown area. I only discovered it for myself around 2005 when I had the chance to drive that way.
30907
The junction at Green Ayre faced Wennington, but AFAIK there were no through services from Castle.
It would have been perfectly possible to run a service (Leeds-)Wennington-Castle P5-Bare Lane-Morecambe, which of course wouldn't have needed the river bridge.
I, too, had always assumed that the Carnforth route back in the 60s still carried significant freight, which made retaining it sensible.
randyrippley
21 Feb 2016
Doing that would have caused logistical problems with the power supply. The catenary was powered from the power station at Heysham Harbour, closing Green Ayre - Morecambe would have broken the feed. So no power for Green Ayre - Castle meaning you'd have to bank anything using it. Too much hassle. Also from memory platform 5 was pretty short - 3/4 coaches only and was the only one accessible from the link
30907
I was assuming DMUs as it was post Beeching and referring to the present loop P5.
randyrippley
21 Feb 2016
Actually I should have said 6 not 5.
I don't think 5 had direct access to the curve. Even for DMU the gradient would be interesting
30907
TBH I'd forgotten about 6, it has been disused since I first visited Castle long after the Green Ayre line had gone. Anyway, apparently both 5 and 6 had access:
https://www.s-r-s.org.uk/html/lmsr/M633.gif
I've not been able to check out the gradient, but it's not one of those I remember from lists of "steepest railway gradients" like Mortehoe and Exeter and Lickey...
Senex
1 Apr 2014
York
The gradient was 1:78 — DMUs regularly work steeper than that, so they shouldn't have had any problems.
Bovverboy
1 Dec 2013
If there were to be no electrics to Morecambe, you wouldn't need a power supply Green Ayre - Castle.
And Heysham Power Station didn't exist when the LM&H electrics were running.
Thanks. Might have been 1/2min quicker in an EMU.
BTW didn't they run a steam push-pull while the line was re-electrified?
