True but all of these things are other reasons to be late. Why do they not say late due to train fault or late due to congestion (the later of which was the reason I got from Cross Country). I think I'm more annoyed at the lack of transparency of rail announcements to be honest.Have you ever been late away from your home "depot" in the morning for work? What causes that? Car breakdown? Flat batteries on the alarm? Power cut? Why would a train and its driver be any different?
A train being late from the depot usually implies that its a fleet/depot infrastructure issue, not a train crew related issue. The actual issue could be anything from a train prep not completed on time, a fault requiring rectification, a signalling issue at the depot, a unit being late from an exam or even an administrative error that removed a service from that depots 'departure' list (when this happens, the first its known about is normally the driver turning up for a diagram that doesn't exist according to the depot). To give complete transparency on these depot issues might only be understood by a minority and more than likely would just arm the complainers with something else to complain about. Also, the relevant control might not know the actual reason until after an investigation has been carried out by the depot, which could be hours after the service has completed its diagram.True but all of these things are other reasons to be late. Why do they not say late due to train fault or late due to congestion (the later of which was the reason I got from Cross Country). I think I'm more annoyed at the lack of transparency of rail announcements to be honest.
That could lead to some very convoluted announcements.True but all of these things are other reasons to be late. Why do they not say late due to train fault or late due to congestion (the later of which was the reason I got from Cross Country). I think I'm more annoyed at the lack of transparency of rail announcements to be honest.
where's the Like button?That could lead to some very convoluted announcements.
"This train was late because it was late from the depot which was because maintenance of the train occurred later than originally planned due to other trains arriving late at the depot; the first train that was late at the depot was delayed due to overheard wire problems, the second train that was late to the depot was delayed due to a signal failure, and the third train that was late to the depot was delayed due to a delay on a previous journey which was delayed due to congestion due to a failed train earlier in the day; these three trains all arriving late to the depot resulted in this train being released from the depot later than scheduled. We apologise on behalf of all the relevant third parties who caused these knock-on delays"
normally this would be quoted as late train crew, as the depot is usually pretty quick to divert blame from themselves when they can.Taxis taking drivers to depot not turning up at booked time or failing to show at all can be another reason for Trains Late from depot.
& any driver manager worth his/her weight will bat the delay straight back at them.normally this would be quoted as late train crew, as the depot is usually pretty quick to divert blame from themselves when they can.
True, but late arrival of a Driver due to a taxi issue is the direct cause of a train being late from depot, and I have seen late train crew due to late taxi being given as a reason in the past by some TOCs. Decent managers should deflect incorrect blame yes, create incorrect blame no.& any driver manager worth his/her weight will bat the delay straight back at them.
Totally agree. Why argue with something for no reason when the root cause is obvious? That wastes everybody's time & just accept responsibility. It's not their own money for goodness sakes.True, but late arrival of a Driver due to a taxi issue is the direct cause of a train being late from depot, and I have seen late train crew due to late taxi being given as a reason in the past by some TOCs. Decent managers should deflect incorrect blame yes, create incorrect blame no.
where's the Like button?![]()
Just say Depot issues & be done with it. The rest is an internal matter.Why does it matter?
99% of customers couldn't care less.
It is only the "rivet counters" that seem to be concerned.
Why does it matter?
Quite, but as usual people who cannot and will not see that.Just say Depot issues & be done with it. The rest is an internal matter.
So if Aunty Mary is told that "due to a late running taxi the driver wasn't collected on time" she is going to know what effect that will have?A reason can be useful and can give an indication of the likelihood of further delay.
Which rather suggests Northern needs to do something about the taxi firm(s) they use. Passengers pay the TOC to provide a service - it's up to the TOC to manage their suppliers, so things like this just shows poor management by Northern.A significant proportion of Northern trains late from the depot, and other delays, around Manchester are down to the taxi firm.
Ever since TPE have have started putting sets onto Crofton, this has affected the on time departures of XCs.Several months ago I was on the 5:19 LDS-STP, as explained by the guard on the train (EMT HST) it was because the reservations had been put on the incorrect train, so it was late off the depot while they swapped them round.
Used to get the Leeds - Southampton Central voyager (06:46 from Doncaster, comes from York now), which after the May timetable change last year got to a point where it was late off Crofton depot more often than on time.
I agree with this.A reason can be useful and can give an indication of the likelihood of further delay.
Sorry but as I said 99% of rail customers couldn't care less about the reason.
Depot Delay is perfectly adequate.
