LMS wagon number plate
gwr2818
15 Feb 2023
Thurrock
Hello,
I have recently come across this LMS 12 ton wagon number plate, number 404348, I was wondering if anyone could name the type of wagon that carried it, or had any pictures of the wagon in question?
Thank you.
Gloster
4 Sep 2020
Up the creek
An unfitted 12 Ton Wood-bodied High Open with steel underframe and 10’ wheelbase. It was built at Derby in 1936 to Diagram 1892, lot 918.
gwr2818
15 Feb 2023
Thurrock
Big Jumby 74
12 Feb 2022
Can recommend a book 'The LMS wagon', by R.J. Essery and K.R. Morgan, David & Charles/1977 if you can find a copy. No actual photos of a Dia 1892/lot 918 wagon, but there is a photo of a one off very similar wagon, albeit a fitted version, to Dia 1892/lot 810, on page 35. Just for info there were 750 wagons built in the range of your w/plate (lot 918), 404000 - 404749.
gwr2818
15 Feb 2023
Thurrock
Thanks for the information, I will check that book out.
furnessvale
14 Jul 2015
A very long time ago as a junior railway civil engineer, I once loaded out a couple of tons of wagon number plates for scrap! I wish I had kept a few!
WesternLancer
12 Apr 2019
That sounds like a lot of wagon plates to make that weight!
furnessvale
14 Jul 2015
Correct. Two reasonable size piles at a location where they had been scrapping hundreds of wooden bodied wagons, but for some reason they left the number plates behind.
WesternLancer
12 Apr 2019
Thanks - interesting to wonder why - when presumably all the other metal components (wagon chassis etc) must have gone into the scrap furnaces. You wouldn't think they would even take the time to remove the number plates from whatever they were attached to.
Perhaps a decision only known to those on site at the time who made the decision!
AndrewE
9 Nov 2015
Maybe the wrought iron and/or steel attracted a better price at the time than the cast iron number plates? Or the company could re-use cast iron internally but not the other stuff?
Or maybe the numbers / plates might have been for use again on supposedly not-new wagons? Apparently quite a few steam locos were not technically scrapped, but a few components were built into otherwise-new locos because of some accounting rule (aka fiddle!)
WesternLancer
12 Apr 2019
Thanks, good point esp ref the price / value of the different sort of scrap.
I have no idea if wagon plates might ever have been re-used, or saved for possible re-use.
Gloster
4 Sep 2020
Up the creek
Could they have been kept back as some sort of proof of how many or which wagons were scrapped? Or were they just a way of simplifying things for whoever had to submit the records of which wagons had been cut: no need to try and decipher a series of badly written pencil notes, just read the original plate?
AndrewE
9 Nov 2015
Equally likely... Did the wagons have plates both sides? if so, count them and divide by 2? or keep 1 off each wagon? (or keep rather more and hope the auditors never made a detailed check of the numbers?)
randyrippley
21 Feb 2016
Cast iron would degrade recycled wrought-iron or steel.
Different impurity profiles
