Manchester London Road on Real Time Trains: does it actually exist?
AY1975
14 Dec 2016
I was looking up London Marylebone on Real Time Trains and it also came up with Manchester London Road, but if you look it up it doesn't list any trains.
I knew that Manchester Piccadilly station used to be called Manchester London Road but according to Wikipedia it was renamed Piccadilly in 1960.
Is there still a location on the railway called Manchester London Road, or is that just a glitch in the system?
If its got a TIPLOC (7 letter/number code for train planning timing point locations) then its probably picked up. There are lots and lots of TIPLOCs that exist that are defunct or have nothing associated with them.
jfollows
26 Feb 2011
Wilmslow
Manchester London Road was the signal box which controlled Manchester Piccadilly between 14 December 1959 and 15 October 1988; it was one of the early power signalboxes built for the WCML electrification, of similar vintage to Wilmslow and Sandbach, both of which have also gone. This meant that the signals on the platforms at Manchester Piccadilly had prefix "LR". Its replacement "Manchester Piccadilly" was initially in the tower block above the station. London Road signal box building was demolished starting at the end of 2007.
In other words, although it doesn't exist any more, it lasted until much more recently than 1960.
https://www.flickr.com/photos/ingythewingy/6920895385/sizes/l/ for a picture. I was lucky to go in it once when it was operational, probably 1979.
Geeves
6 Jan 2009
Rochdale
Potentially before Network rail had a change of heart in the "Everything must go in the ROC" plans. Now in the too difficult pile.
Mugby
25 Nov 2012
Derby
It really ought to revert to it's former name of Manchester London Road. Piccadilly is not exactly an apposite indication of it's location!
185
29 Aug 2010
Exactly the same as Birmingham New Street. Everything was moved to a big signalling centre except the one remaining station panel. Less of a problem at New St, but Man Picc has some very long waits handing trains over.
That said, the ability of station staff to speak to the box directly via handheld radio is key, so that should be factored in with any move.
SargeNpton
19 Nov 2018
No TIPLOC, but NLC 286500 is shown as "MANCHESTER LONDON ROAD(CLSD)".
A redundant location then that RTT seems to have included in its Pick List just because.
pdeaves
14 Sep 2014
Gateway to the South West
Rather, a redundant location that is in the feed RTT receives and is automatically processed the same was as all other locations.
SargeNpton
19 Nov 2018
But, as it has no TIPLOC, is cannot be a timetable location - so RTT should be filtering it out on that basis.
There are around 55,000 NLCs, of which just under 12,000 also have TIPLOCs. What does RTT do with those other 43,000 locations that do not have TIPLOCs?
Shwam3
13 Jun 2011
Norwich
The version RTT will be using is NLC 296801 with TIPLOC MNCRLRD
New St goes at Xmas.
Geeves
6 Jan 2009
Rochdale
We have been talking to the box via radio from Manchester Victoria to the ROC at Ardwick for a few years now, so not an insurmountable problem :D
185
29 Aug 2010
Rumour has it the Piccadilly Manrail works as far away as a certain chain establishment in Piccadilly Gardens where you can order food to your table via an app.
Oh... Allegedly. We only found out after someone forgot to take it off their belt after work. ;)
SargeNpton
19 Nov 2018
Interestingly, the STANOX descrption attached to that location describes it as "MAYFDLOOP". Possibly then the old link from the main line to the former Mayfield parcels depot (and what was Mayfield station before that).
