Meridian (and Voyager?) Door Seal
whhistle
30 Dec 2010
On a Meridian (and I assume Voyager) when the train door closes, there is a gap on one side, the side opposite to the mechanism.
This is then sealed a few seconds after moving off.
Can anyone tell me what is happening here / why this is like it?
Pumbaa
19 Feb 2008
Purely for comfort and to reduce noise/air flow. Train can still operate at line speed without it.
There is a seal (a bit like an inner tube of a bicycle where) which inflates and essentially fills the gap left between the door and the body, triggering at a few mph.
I always thought it was a nifty compromise against a fully recessed plug.
Doomotron
25 Jun 2018
Kent
While the 395s (and 80x I believe) have a roller mounted on a pivot which activated at ~5mph to push the door outward.
On the 395, this only happens when the guard or driver opens the doors, but it does seal normally when accelerating. This is annoying because pressing the door button doesn't do anything after it lights up because of this (I wish it worked like in the 80x).
rebmcr
15 Nov 2011
St Neots
If they went through all that effort, why didn't they just make them plug doors in the first place?
Hitachi really insisted that the product should have the sliding doors they were already familiar with (from building JR stock). They are responsible for the reliability contract after all.
The Japanese version is I think primarily a seal to reduce the change in interior pressure when passing other trains at high speed, particularly in tunnel. Presumably it also eliminates the annoying door rattles that are such a feature of our 1970s and 1980s units with pocket doors. Hitachi did accept a plug door for the 380s - not sure if they've been noticeably more or less reliable.
urpert
1 Dec 2015
Essendine or between Étaples and Rang-du-Fliers
And given the 395s pass through single bore tunnels at up to 140mph you can see why they would want the same system!
