Merseyrail Class 777 introduction updates
shakey1961
21 Dec 2014
Is anyone going to Oriel Road to see it arrive? I'm hoping to be there. Don't want to go if there's some sort of ban with social distancing etc.
Skie
22 Dec 2008
Don't understand why 777001 and 777002 have not yet arrived here.
Has been mentioned a few times.
001 went to the test track without the tunnel egress door fitted, as they were awaiting the parts but having it fitted wasnt required for the early testing.
002 was the first to be given the tunnel egress door, and was sent to the test track to replace 001 (not sure if they did multiple running or just straight swapped)
001 headed back to the factory to be given the door.
Jamesrob637
12 Aug 2016
I saw it through Acton Bridge. Nice looking but boy they'd better double up on peak services in 2021! Either that or a 2-minute frequency :D
urbophile
26 Nov 2015
Why do they have those long flat trucks between the locomotive and the new train? Social distancing?
Murray J
10 Aug 2019
East Grinstead
no idea, but not social distancing as they were on the first move back in January, my guess is either to act as barrier wagons (I don't recognise the wagons so I would suggest they probably have new couplings installed) or to protect the train from damage.
Domh245
6 Apr 2013
nowhere
Barrier wagons and Brake force. The units are dragged completely dead with brakes isolated, so those wagons are needed to give the train enough brake force to stop safely. You can even see how they get the brake pipe to run through the 777 without using it's own pipes - lots of tape and a slightly opened cabside window!
Chris217
7 Nov 2018
Yeh,I noticed all the tapework lol.
DJH1971
10 Jun 2012
St Helens, Merseyside
They are noted on Wikipedia as being dual voltage, but do they have a pantograph fitted?
Not quite made anything out in the pictures.
Energy
29 Dec 2018
I believe it is currently 750v 3rd rail + option for batteries. However there will have to be an area for a pantograph to be fitted as all new build UK EMUs are required to be able to be easily converted to use a pantograph.
shakey1961
21 Dec 2014
Thank you to M28361M for the post which I had notified by email. I'd just gone to bed, so it's lucky I checked. Only live half a mile from Birkdale station so I was there in good time.
777 003 I caught it passing through Birkdale Station about 22:20. Very quiet! First one I've seen out in anger!
shakey1961
21 Dec 2014
According to the route that's been set on Traksy - it's on its way back to Southport. Are they going to be running this up and down all night?
It doesn't appear to have a pantograph well. Maybe an exception because they are very unlikely to be used elsewhere?
Energy
29 Dec 2018
This image from wikipedia shows a pantograph at the end of the left driving vehicle, not sure if the image is totally accurate but from the looks of it the pantograph isn't easy to see when it isn't up, (it will have probably been fitted to a couple vehicles to test)
Interesting. I wonder if the roof is lower than normal stock, thus removing the need for a well (as 50x are lower than the Mk3 based EMUs)? If so, I'd imagine it couldn't run through the tunnels with one attached without whacking it?
Energy
29 Dec 2018
Maybe, Stadler will put more equipment on the roof than others due to their low floor design giving less space underneath, the extra equipment may make it harder to see the pantograph.
Liverpool 507
17 Jan 2018
Merseyside
Those ’Pantograph’ areas on the roof of the unit are currently covered with panelling which I’m sure can easily be removed if there are any future developments on the Merseyrail network.
Energy
29 Dec 2018
Makes sense, makes it easier to clean the units I guess.
Energy
29 Dec 2018
Umm it can do all of these? Batteries being able to be fitted was a requirement.
Skie
22 Dec 2008
It can’t do all 3 at the same time. All units have some batteries for depot moves, but for mainline running the extra batteries go in the same space that the rectifiers for 25kv would go.
So they can do:
  • 3rd rail (as delivered)
  • 3rd rail + mainline batteries
  • 3rd rail + 25kv overhead
