nanagrampy
- Joined
- 26 Nov 2012
- Messages
- 12
Hi all,
I know this sort of thing will never happen but I think that a railway line pretty much following the M25 would be a good idea.
There could be links to so many railway lines, meaning people only have to change once from London to get to so many different places. It could also be connected to other lines, so if there is a problem on a line, then the trains could switch to a different London line using the M25 line.
You could then link the line up to Heathrow, and build a Heathrow terminal 6. This would be a huge airport like terminal with links to the M25 line, HS2, Crossrail, Heathrow Express, the Piccadily line and most importantly HS1 services. This could be done by using a high speed line around the M25 and then having a link line along the M26 and across some countryside to the HS1 line at the M20. You could have some European services terminating at Heathrow instead of central London. And as more European destinations are being added, it would be an alternative to flying, but still from the airport. By doing this, you free up airspace at Heathrow and encourage the use of rail.
So basically, why not build a (maybe 6 track?) railway line around the M25 providing high speed rail, local connections and train diversions.
I am sure you will all have views on this which I will be very interested in hearing.
PS. I am a beginner to RailUK so apologies if my post is a bit unclear.
