Those torpedoes behind it are used for transporting molten steel, similar are still used on the European network between different plants and the signallers have strict instructions not to halt them under catenary, unless in a dire emergency, as they would quickly melt the wires!The very low profile reminds me of the older locos used at the Beckton gas works which had to enter the limited clearance of, I recall, the retort houses where the coal was cooked to produce the coal gas and produced coke. I vaguely recall from geography lessons in the early 1960s that steelworks had their own coking plants, so was this loco (diesel or battery-electric?) used in a similar way?
North British 'Miner' Locomotives
During the 1940s and 1950s the North British Locomotive Co (NBL) built a number of small compact 0-4-0 locomotives, specially designed for use in underground mines. For some of these North British 'Miners', Paxman supplied its 6-cylinder RQE engine, rated at 100 bhp at 1,250 rpm and fully flameproofed for underground working. (NBL also built Miners with Crossley 100 bhp 5BWL engines and Leyland 75 bhp AU 350/16 engines.) The Paxman-engined Miner had a maximum weight of 15 tons, a maximum axle load of 7.5 tons, a maximum tractive effort of 8,400 lbs at 25% adhesion, and a maximum speed of 15 mph. Some 6RQE engines for Miners were fitted with Metalastic couplings to drive an SLM gearbox. Others were supplied suitable for driving a fluid coupling connected to a Wilson gearbox.
Thirteen 6RQEs were despatched to NBL in 1948 for Miner locomotives, several of which were supplied to National Coal Board collieries in northeast England. A further seven 6RQEs were supplied to NBL in late-1953 for mine locomotives. These were 'standard build' industrial engines which Paxman happened to hold in stock. It is not recorded whether, after despatch, they were converted to flameproofed types but this seems likely. (End-users cannot easily be identified as Paxman's RQ records have not survived.)
In addition, a non-flameproofed 6RQE was supplied for a locomotive for Rhodesian Copper Refineries, as explained above.
It looks to me like it might be battery powered. It reminds me of the 'flying buffer beam' at Quainton Road (see https://www.steamlocomotive.info/largeimage.cfm?which=4182).I'm not convinced it's a loco, by the way - doesn't look like it would have much traction!
I did think battery loco too.It looks to me like it might be battery powered. It reminds me of the 'flying buffer beam' at Quainton Road (see https://www.steamlocomotive.info/largeimage.cfm?which=4182).
I think it looks like a diesel with low level controls at one end. There’s also something RSH about it to me.
Many thanks for solving this mystery. It's a shame it was scrapped. Was it unique or was there several at Firth Browns,or indeed did any other companies use them?This question made its way to the Industrial Railway Society discussion on groups.io, and thanks to the incredible knowledge on that group I can provide some answers, gleaned from an article in Industrial Railway Record Issue 169 written by Cliff Shepherd. This contains far more detail on the loco than I have included here as well as two images of the loco.
The locomotive is a Hawthorn Leslie 0-4-0 diesel, works number 3913 of 1937, (actually completed after that company had become part of Robert Stephenson & Hawthorns). It had a Crossley DRL.4 direct reversing engine and was built to a very low height due to restricted clearances in the armour plate rolling mill and heat treatment furnaces at Firth Brown’s Works. It had a maximum speed of 6mph and weighed 22.4 tons.
It was initially numbered Firth Brown 25 and later became D1. It was scrapped in 1967.
