Network rail second test?
RK19
14 May 2018
I’ve applied for a few technician jobs and passed the first test, a basic mechanical reasoning test.
My application now says im under consideration for second test, what will this likely be?
Sinistah
18 Jun 2017
If it’s assessment 2 it’s an interview mate best of luck. You should have received an email by now with a letter explaining that it is under consideration with the hiring manager.
RK19
14 May 2018
Right ok good, what sort of things will i be asked you think? Im coming from a background as a motor mechanic, what should i brush up on?
Sinistah
18 Jun 2017
Tbh mate it should be based on the 8 non technical skills and the safety vision. If it’s the same as the signaller interviews. Hopefully someone else in your field may be able to enlighten you. It’s gonna be tell me about a time sort of example based interview
RK19
14 May 2018
Cool so wont be related specifically to the job? What sort of questions do you think they will ask?
Cavan
7 Jan 2017
I would check with HR on any interview format for engineer and technicians jobs - I suspect there will indeed be "non-technical" skills questions, however they most likely will also ask about your technical skills/knowledge/experience/technical scenarios etc if it is like any other interview for a technical role.
RK19
14 May 2018
Thanks, just a bit worried as im coming from the motor trade so dont have any rail experience, but i know id pick it up quickly if i got the job, just want to be as prepared as i can for any questions they might ask.
Sinistah
18 Jun 2017
Just look at the essential skills listed for the job spec. Then basically answer the question tell me about a time when I did these tasks. Make sure you are armed with examples
RK19
14 May 2018
Cheers mate.
Cerebral
4 Jun 2014
As others have said. Definitely prepare well with scenarios of a time when you showed this skill, or that competency that is essential to your specific job role. Cannot emphasise enough being properly prepared, your competition will likely be stronger than you expect.
RK19
14 May 2018
Brilliant cheers.
Sinistah
18 Jun 2017
Yeah an emergency situation where I have had to work calmly under pressure and how you dealt with the situation. What did you do that made the difference
Sinistah
18 Jun 2017
Just prepare for anything mate. Don’t want to lie to you would only be guessing
