Northern Class 769 Diagrams
leomartin125
15 Nov 2015
North West
I am now looking for updated Northern 769 diagrams. The FOI request links to diagrams that aren't even being followed, I have checked today and as far as I can see, zero 769 units are out - any diagrams are covered by 150/156. Is there a reason that the 769s seem to be not operational on a Saturday?
Just because they are being covered by 150s or 156s doesn't mean they aren't 769 diagrams officially.
The 769s appear to have been stood down for some reason.
leomartin125
15 Nov 2015
North West
The 769 diagrams I was referring to were the official ones published by Northern as a direct result of that FOI request above.
Unsure as to why they have been ‘stood down’ - sounds ominous!
thealexweb
5 Jan 2014
Is this connected to the 769 which shut down between Salford and Bolton earlier in the week? It caused hours of delays.
Greybeard33
18 Feb 2012
Greater Manchester
From RTT, 769431 & 434 were in traffic on Thursday 12 October, but both were withdrawn before completing their diagrams. It appears that 431 failed at Moses Gate westbound at 1848, then 434 was withdrawn at Bolton eastbound at 1902, presumably to go and rescue 431. It was not until 2115 that another train made it through from Manchester to Bolton. See
for discussion of this incident.
No 769s have been out since.
M60lad
31 May 2011
I'm not even to sure to be honest whether Northern actually use all of their 769s each day as I've often seen at least one set stabled at Newton Heath and also on Saturdays whenever I've been passing Allerton Depot on 18:22 Lime St-Oxford Road service there seems to be at least 3 or maybe more stabled up out of use usually inbetween 319s.
Greybeard33
18 Feb 2012
Greater Manchester
See the 769 rolling stock thread for previous discussion of reliability issues:
driverd
29 Mar 2021
In fairness its quite normal to only utilise a percentage of a fleet. I've not scrutinised the diagrams upthread, but would expect atleast 2x 769s on book maintenance diagrams per day.
As others have said (and in particular due to how diverse northerns fleet is), just because a 769 is allocated, doesn't necessarily mean you'll get one - in the same way an allocated 150 could easily end up a 156.
AMD
6 Dec 2017
As noted above, the failure of 431 and the use of 434 to rescue it has wiped out availability of the fleet.
There are currently 2 units away for mods at the moment, plus Network Rail will not allow a 769 out in service unless theres another one available for rescue purposes, so the micro fleet is even smaller than usual.
thealexweb
5 Jan 2014
Northern's ambitions to have six of the eight units in use daily from December look ever more remote...
Greybeard33
18 Feb 2012
Greater Manchester
The current diagrams show that 4 units should be in traffic M-F, with 2 units away for mods and 2 on exams. Today RTT shows that 769434 is the only unit in traffic, on diagram AN291. The other 3 diagrams are being worked by a 156+150 combo, a 156+156 combo and a solo 156. So presumably two 769s are currently demic, with a third sufficiently serviceable to rescue 434 if necessary.
Edit: But see #15 & #19 below for clarification.
Geeves
6 Jan 2009
Rochdale
Another 769 came out this morning otherwise it would still be zero!
424 is the other one coming off Newton Heath and the 156s swapping onto the Tod Blackburn work
scrapy
15 Dec 2008
If there are not 3 serviceable 769s available, none come out as there needs to be one available to rescue a failed unit. (And one to rescue that incase of further issues)
