Envoy
- Joined
- 29 Aug 2014
- Messages
- 2,818
I don’t think that things are being made easy at Newport for passengers changing trains. The easiest platforms to change trains at Newport is the island platform 2 and 3 with 2 normally being westbound trains and 3 being eastbound trains. P1 is normally used for westbound trains that can't be accommodated on P2 and P4 for those that can’t be accommodated on P3. P1 might also be used for late running services that can’t make it to Cardiff & back to form services going east again.
As an example:-
This morning1B05 London > Swansea calls at P2 at 9.27. P3 has 1L12 Carmarthen > London at 9.30.
At 9.32 1F06 Portsmouth > Cardiff is on P2. At 9.36 1W92 Cardiff > Holyhead is on P4.
So, we have a situation where westbound and eastbound London trains call at the island platform yet nobody is going to change trains between these services. For both the westbound train from London and that which has come from Portsmouth, the train that people would want to change to is 1W92 Cardiff > Holyhead = the very train that requires people to cross the bridge and get to P4.
So, why can’t 1L12 Carmarthen > London be accommodated on P4 being as nobody will be changing and 1W92 use P3 to make an easy level switch of trains for those passengers coming from southern England/London wishing to head up The Marches?
I don’t think it is an advertised connection at Newport between the train from Portsmouth and that going to Holyhead being as the timings are so close. That is a pity as the trains to north Wales are only very other hour usually. Surely the schedules can be tweaked to have an advertised connection at Newport for these services - especially if the island platform is used for passengers to swap services?
Surely the rule should be that all trains heading up The Marches will use P3 at Newport.
As an example:-
