Hello
Next Saturday (25th) the clocks change by 1 hour at 2am. The same happens in October.
What happens to overnight trains in Europe on these nights? Do they run early/late in the evening/morning to accommodate for this?
This upcoming night is 1 hr shorter and I remember from by now quite some time ago the delay next morning will hence be at least 1 hr (The best known current nighttrains, OeBB NightJet are nearly invariably late on arrival-most often due to extended times for the shunting split/combine they have in the mid of night). There may be the occasional case where there is slack in the timings-often to give clients a decent night sleep and not too early arrival, ZSR in Slovakia has such a train-but this afaik does not run nights sat/sun!
When we revert to wintertime late oct. most often there will be a standstill in some convenient spot for 60 mins-or less to wipe out delays-but in this night staff rosters and working hours and all that may also influence it. These differ quite a bit per country.
The 2/3 overnight trains in GB (Scotland and Cornwall) probably also not run those nights sat/sun?
In Sweden the overnight trains either stop for an hour along the way or become delayed by an hour.
ELL says hiThere’s far more overnight passenger trains than just the Cornish and Scottish sleepers. Services run all night on Thameslink, Paddington to Reading and Transpennine amongst others however in all these cases like the sleepers they don’t run on a Saturday night.
ELL says hi
ELL says hi
I don't know about international sleeper trains, what about those people who who work nights in this country. When the clocks went forward your shift ended early by one hour. But the person who copped it in the Autumn ended up doing an extra hour.
East London LineELL?
Of course - thanks!East London Line
And a lot of thick black exhaust, undoubtedly...Back in the early '90s I remember taking the 01:40 (I think it was?) from Halle to Nordhausen all-shacks stopper on that night, which after its first stop would be an hour late, all other things being equal. As a result, the driver just decided on an alternative strategy of, after Angersdorf, driving like a complete nutter to reduce the deficit. With a DR Ludmilla on load 3, it was a case of "hold on tight"!!!!
Ah, they all clag less at night....And a lot of thick black exhaust, undoubtedly...
Although Southern run Victoria - Three Bridges for all of Saturday night!There’s far more overnight passenger trains than just the Cornish and Scottish sleepers. Services run all night on Thameslink, Paddington to Reading and Transpennine amongst others however in all these cases like the sleepers they don’t run on a Saturday night.
As treinposities.nl also logs historical departures in the Netherlands, thought it might also be a nice addition to share some screenshots of trains during the clock change... (Be aware that at NS trains departing between 0.00 and 4.00 hrs are running during the night following the day mentioned, so a 2.16 Saturday departure is actually running early Sunday morning)
Departures from Utrecht Central during the night of 30 to 31 October 2021 (changeover to winter time):
The log of the departure at the "second" 2.16 hours messed up computer systemsand took -47 minutes to run from Amsterdam to Schiphol:
In contrast, the log of a train passing through the transition to summer time in 2022, taking a whopping 1 hour and 15 minutes from Amsterdam to Schiphol:
These are long distance intercity trains? An hourly service overnight wow! There are long distance trains in my country that are twice weekly! Even a daily service is a dream let alone hourly. They really do have it good there.
As for daylight saving the normal situation here is the train runs 60 minutes late or early depending on the time of year. A service notice is issued in advance so passengers know.
With cross border services eg NSW to Queensland each operator uses local time for entire route even after crossing the border into Queensland time. Queensland doesn't use daylight saving time and is same time year round.
But they do have cross border commuters but that border at Tweed heads tends to operate like an international border where local buses shall not cross and you must change buses and walk across border! Only long distance buses cross the Queensland border. Only one train a day cross the border via an isolated border tunnel in the mountains much further inland. There is only one cross border railway line into Queensland and its single track and has only one station in Queensland at Brisbane Roma Street.
Hardly - long distance and Netherlands don't belong in one sentenceThese are long distance intercity trains?
