Oxford to Manchester
orpine
24 Aug 2013
Does anyone have any suggestions for an Oxford to Manchester trip in late January, with an outward journey at about 18:30, and the return starting at ~09:30.
The offpeak return is £74.
I've priced up a few options and got it down to about £50 with a set of advances.
* Oxf-Leamington
* Leamington-Stafford
* Stafford-Manchester
Any variants I should take a peek at?
Thanks.
(also, why are split-ticketing sites so useless? I inevitably end up having to create a matrix spreadsheet of my own when I do this, but it's a bunch of effort).
MarlowDonkey
4 Apr 2013
Cross Country run a through service I think.
For the right days and trains, you might get a cheap Advance all the way through.
You could also consider Birmingham splits.
With a really cheap Euston to Manchester or vice versa advance, a via London route might be feasible.
NorthOxford
13 Feb 2012
I used to do this journey a lot. Missus living in Oxford, me in Manchester (before I moved).
Between Leamington Spa and Stoke or Crewe you could try a West Midlands Day Ranger for £24.80 http://railrover.org/pages/west-midlands-day-ranger.html and them advances for the rest.
Alternatively you could try the megabus which is just over an hour more than Cross Country..
orpine
24 Aug 2013
Thanks for the thoughts.
Yep, XC have a direct service; that's the one that will be used. I hadn't considered via-london, but that's too much hassle slow and there are no cheapies.
Birmingham splits I looked into and they're quite expensive (it always seems cheaper to split at Leamington).
The Day Ranger is an idea, but alas it's not a day-return so it won't work out here.
Megabuses I hadn't considered (I didn't know they'd expanded to do non-London based places) and they are damn cheap (only £8 each way), but unfortunately completely the wrong times. Buses in this country only seem to have one a day for most routes. :-/
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
If you want to use the through CrossCountry train then my feeling is you'll not do much better than splitting at Leamington Spa and Stafford - they are good split points for this journey.
If you're happy with a longer journey, try this:
Oxford - Banbury CrossCountry advance £3.70
Banbury - Birmingham CrossCountry advance £6.50
Birmingham - Crewe London Midland advance £7
Crewe - Manchester Northern advance £3
I think you should be able to do it for about £40 on split advances like this.
