Permitted routes on TOC-restricted tickets
evil_hippo
9 Jun 2005
Lewisham
I'd like to check on something that's a little ambiguous in the wording of the routeing guide.
Are tickets which state one or more TOCs in the 'route' section, but no other route restriction, valid via any permitted route provided those TOCs are used?
For example, suppose one wished to travel to London to Coventry and later return from Nuneaton to London.
A ticket from London to Coventry via Any Permitted Route is valid for travel via Nuneaton, using map TV. It is therefore valid to return from Nuneaton.
By association, it would seem that a ticket from London to Coventry via WMTrains Only should also be valid via Nuneaton, as it is a permitted route and WMTrains operate services over the entire route.
Can anyone confirm or deny this interpretation?
furlong
28 Mar 2013
Reading
Yes. The TOC restriction applies on top of the "any permitted" routeing stipulated by the guide. (There have been some errors in the past where fares were created that had no validity because there were no routes in the guide for that journey that used only the named TOCs.)
They’ve painted themselves into a corner somewhat using one space on a ticket for two separate issues.
Should have had a routeing area, and an operator area.
Bit late to change now I expect.
gray1404
3 Mar 2014
Merseyside
Are tickets which state one or more TOCs in the 'route' section, but no other route restriction, valid via any permitted route provided those TOCs are used? I would say yes, totally.
