Platform 3R King Cross?
GraceM
6 May 2022
England
Hi,
I think this may strike as a silly question but I'm new to train travel. I'm departing from platform 3R at King's Cross on Sunday. I usually just depart from regular plat 3. Can anyone tell me what 3R means?
Thanks so much.
Hi, and welcome to the forum.
It’s meaning a half of platform 3, I believe they refer to them as F for Front and R for Rear, (ie nearest the buffers), if there are two separate trains in the platform together. Do you know the departure time and destination, then we should be able to check exactly what’s going on for you.
DanNCL
17 Jul 2017
County Durham
Hi,
Thanks so much.
It means the rear train (closest to the buffers) from platform 3. It’s possible there may be two trains sharing the platform which is why they mark it as such.
BJames
27 Jan 2018
Thanks both of you :)
It's departing at 14:48
This is indeed the rear portion of Platform 3. An LNER service to Lincoln is departing at 14:35, this uses the front part of Platform 3.
This happened to me the other day as a Lumo service took the front half and Hull Trains took the rear, the guard repeatedly announced that we were the Hull Trains service and would be going nowhere near Newcastle. Nevertheless they didn't advertise the platform for the Hull service until Lumo had left anyway.
I don't think I recall ever actually seeing it on the departure boards at the station marked 3F/3R - last week it just had a scrolling display at the bottom of the Lumo train saying "front train only" - and the rear train, the Hull service, remained locked during this boarding time.
That’s a Hull Trains departure. So what’s happening is the southbound train arrives at 1342, and sits for over an hour, and while it’s there at the buffers an LNER service comes in and leaves for Lincoln as @BJames just mentioned.
You shouldn’t have a problem as long as you make sure you get on the Hull Trains service, I guess you’ll be familiar with the different livery and branding?
GraceM
6 May 2022
England
Yeah, I'm accustomed to the branding :)
So am I having to walk down the platform a bit for my train or will it be nearer the bit where people walk in and out where the departure/platform signs are? I'm just making sure :,)
Nearest the gate line and screens.
Certainly never been displayed like that at King’s Cross.
Platforms 9-11 used to be designated A and B, which was commonly used on departure boards and in announcements, but that seems to have fallen out of use with the almost complete elimination of 4-car working at King’s Cross.
You also occasionally get a “3M” designation in the timetable, which means the middle train on platform 3. Much rarer, but it has been seen in some timetables over the years, for example when a 12-car arrives and divides into three units.
I didn’t actually consider if it was displayed in the station that way, but I think we have to presume the OP has seen it somewhere online, presumably in a journey planner?
2192
16 Aug 2020
Derby UK
"Front train" and "Rear train" are OK as descriptions at a terminus if passengers join the platform at the buffers, and the second train is locked with the lights out until the first has gone; but announcements like "First class is at the front of the train" are confusing if the train is going to change direction, such as Nottingham - Birmingham trains at Derby.
D365
29 Jun 2012
I hope that the use of non-sequential suffix letters doesn't become a regular occurrence. As evidenced by this thread, it introduces an element of confusion.
Kenny G
20 Mar 2014
Completely agree it is ambiguous. To some the front will be the point nearest to them.
norbitonflyer
24 Mar 2020
SW London
"Front/rear" does cause confusion at etermini. Someone I know always assumes that "front" means the first bit you come to on passing through the barriers - after all, it was the front when it was last moving......
JRT
11 Nov 2020
Bradford
Shipley platform 3 is sometimes designated 3W (where the North Bradford Electrics stop) and 3E (where ecs wait for the signal) but this is only used on RTT etc.
D365
29 Jun 2012
It’s not even the front/rear concept, just the use of single non-sequential letters. Until I understood the context, I had no idea what 3”R” meant.
