Please can anyone advise: does the lever for hand points have to be right next to them, or can they be operated remotely by means of rodding etc. under the adjacent track? The situation is a trailing crossover where we would ideally like the levers for both ends of the crossover to be operated from the same side of the line, to avoid a shunter having to walk across both lines to get to the other lever. The points in question are fitted with modern Racor mechanisms rather than the traditional straight levers. And if it is possible, is it a big piece of work? Thanks
