BerkshireRails
If DC Upgrade takes place they will install third rail between Kew Bridge and South Acton. Personally I think they should wire to Brentford if the DC Upgrade takes place so that then there is no need to install third rail in the Kew Bridge area and it would be an extension of the AC & DC system already in use at Acton Central. North London Line services in the Down Direction would pan Down at Acton Central and if they fail to switch they can run on the wires to South Acton and be turned there and Up North London Line services would pan up at South Acton and if they fail to switch they would reverse at Acton Central and stored in a platform at Richmond.So it's essentially a 25Kv (only) system, with a fairly long battery extension? (i.e. no DC) That should improve the case, for putting wires all the way between Brent Cross and Acton Wells.
I suspect a static battery fast charging solution (like GWR's 230) would be pushing it, on a higher frequency LO service.
And a DC upgrade (while perhaps desirable for other services) doesn't solve the third rail gap.
Map from Network Rail which publicly accessible.
They mentioned if they went for Third rail they would have to pay a lot of money to upgrade the third rail.There was a brief mention in that PWI video about how SWR wish to run more Hounslow Loop services but power supply is the most limiting factor. Wimbledon Grid is quite stretched powering everything from Clapham Jnc to Surbiton, Virginia Water and Windsor (and a few other bits) - maybe a new Grid supply in Twickenham (where there is a 132kV substation) would help? Well out of the scope of the LO project though it may have to happen eventually.
