Post Integrated Rail Plan services in Yorkshire
Glenn1969
22 Jan 2019
Halifax, Yorks
Just wondered what people think the Government will actually do to improve connectivity between the 7 major cities in Yorkshire and how they will ultimately connect Leeds and York to HS2?
MattRat
26 May 2021
Three 'options' as I can see it:
- Via Manchester on the Western leg.
- Heavily upgraded MML.
- Connect HS2 to ECML.
Glenn1969
22 Jan 2019
Halifax, Yorks
I get that
However some of the regional connections are currently poor with Sheffield-Leeds and Sheffield-Manchester connections currently worse than Manchester-Leeds. I think these need consideration and the lines between all 7 cities in Yorkshire need to be wired as soon as practical
Purple Orange
26 Dec 2019
The North
There will be services to Birmingham via Manchester as that will be the fastest route from the north east.
Glenn1969
22 Jan 2019
Halifax, Yorks
Surely any time savings will be marginal given how much of a long way round it is. And Sheffield- Leeds as a corridor is more in need of improvement than Manchester-Leeds (or is that just me?)
Purple Orange
26 Dec 2019
The North
And how does that improve services between Yorkshire cities?
I was answering how Leeds-York will be connected to HS2.
Leeds-Manc-Brum will be 89 mins according to the IRP, which is a time that Leeds-Sheffield-Brum won’t be anywhere close to achieving.
Glenn1969
22 Jan 2019
Halifax, Yorks
But in the IRP it's not clear that there will be direct services. Anything involving connection will add to the journey time.
tbtc
16 Dec 2008
Reston City Centre
Agreed - but the plans are for yet more money to be spent on Manchester - Leeds
Based on the main train station in each city, the "as the crow flies" distances are:
Leeds to Sheffield: 29:00mi
Manchester to Sheffield: 32.37mi
Manchester to Leeds: 35.58mi
...yet Manchester to Leeds is going to be significantly faster and more frequent than services from either of those cities to Sheffield. If you miss the one "fast" train per hour from Leeds to Sheffield then you could be in Birmingham in a similar time to the time a slow train takes from Leeds to Sheffield
We were meant to be getting a properly fast Leeds - Sheffield line as a "sop" for cancelling the eastern side of HS2, if the rumours were true, but electrifying a second route from Leeds to Bradford seems to have been more of a priority
We'll have a passing loop on the Hope Valley line between Sheffield and Manchester some time in the next twenty years, I guess, so we should be grateful for that!
I'm struggling with the "seven", unless you are including Ripon as a "major" city that needs electrifying?
Leeds, Bradford, Wakefield and York are clearly already electrified, Sheffield will be getting wires when HS2 comes (albeit at the southern end), so it's really Hull that would have an unnelectrified Yorkshire station (?)
Purple Orange
26 Dec 2019
The North
It does. Look at page 12 on the IRP, where it states that there will be direct Birmingham-Leeds services in 79-89 minutes.
Glenn1969
22 Jan 2019
Halifax, Yorks
Yes it does having read it again
West Yorkshire actually comes out of this quite well- but only if WY Mass Transit is built in full. Which I hope it does.
Purple Orange
26 Dec 2019
The North
There is also a line about NPR going as far as York, which would mean that the services to Newcastle would be the Birmingham trains and the services from Liverpool terminate at York. I’m a bit intrigued as to how Hull will be served if it is not being electrified, but I guess that’ll be the semi-fast services that continue using the existing line.
Peterthegreat
22 Feb 2021
South Yorkshire
I count 5: Sheffield, York, Leeds, Hull, Bradford
The seven Yorkshire (historic boundaries) cities are those plus Wakefield and Ripon. The seven largest places are:-
Sheffield
Bradford
Hull
York
Huddersfield
Middlesbrough
The seven busiest stations are:-
Sheffield
York
Huddersfield
Doncaster
Bradford Int
Hull
2 Jan 2009
However you define them, IRP does nothing for Yorkshire. TRU was already happening and will be made less effective trying to ram HS services down it as and when the new tunnel opens in 2042. Leeds to Sheffield scrapped. Leeds to Bradford pie in the sky guess that NR now need to laugh at. No new Leeds station and approaches. Its a pretty raw deal.
Glenn1969
22 Jan 2019
Halifax, Yorks
That's kind of my thought as well. When I said 7 Cities I forgot Doncaster isn't a city
