Powderhall branch to close
och aye
21 Jan 2012
http://www.broughtonspurtle.org.uk/...files/backissues/Spurtle 271 Final Hi Res.pdf
A Green Party motion prioritising development of the Powderhall railway line as a footpath/cycleway drew unanimous support from the North East Localities Committee on 19 February.
The route is already safeguarded under the Edinburgh Local Development Plan, but this new move aims to give the proposal extra impetus.
Officers said scheduling work was impossible for now as talks with Network Rail have not yet established the likely extent/cost of repairs (especially to bridges or embankments) or other liabilities or indeed the length of line to be released. (The current best guess is from Powderhall to the Lochend Butterfly.)
Cllr Susan Rae (Ward 12) sees potential for the route to include public art impelled by the area’s ‘bucketloads’ of ‘imagination, drive … ambition and intelligence’. Vice Convener Amy Mcneese-Mechan (Ward 12) said she is ‘1,000% behind the plan’.
Sustrans may now be approached to fund a feasibility study, and progress will be reported in the NEL Committee’s business bulletin in 6 months’ time. The Transport & Environment and Finance & Resources Committees will be kept informed.
Highlandspring
14 Oct 2017
The Powderhall branch is already closed and permanently Network Changed out of use.
och aye
21 Jan 2012
It's always a shame when railway lines close, but given that the majority of this branch line is next to useless, pruning it back to the Lochend butterfly makes sense.
railjock
30 Jun 2012
I
if the abbeyhill loop is ever to be re-instated NR need to keep ownership of part of it.
Ginaro
23 Aug 2016
Cutting it back to Dryden Gait, Leith Walk or Easter Road to begin with would be a good start for a cycle route whilst keeping NR happy.
och aye
21 Jan 2012
But what use would the line going out to Leith Walk or Easter Road be?
Surely the only useful section to hold onto would be up to the Abbeyhill junction?
Ginaro
23 Aug 2016
Well yes, but I'm just thinking it would be easier to sever and secure the line further along to begin with.
railjock
30 Jun 2012
Protecting the solum from Abbeyhill to Easter Road may be sensible for potential stabling but I can’t think of a reason for keeping the Powderhall line past a potential Abbeyhill junction.
InOban
12 Mar 2017
To provide a third, or even fourth track between Waverley and Jocks Lodge. It could cross over the fast lines to allow a conflict-free route for Borders trains and ECS.
railjock
30 Jun 2012
I was supporting that but you don’t need a line to Easter Road for that.
Ginaro
23 Aug 2016
An update on the progress of turning this line in a cycle path. The waste transfer site will be turned into houses at some point, seems a bit pointless to keep a dead end line designated as a "strategic rail freight link" past Easter Road.
NR advised that they are currently investigating options for increasing passenger service capacity on the east side of the city. They expect to submit an evaluation of these options to Transport Scotland (TS) for consideration in mid-2020.
Some of these options could potentially involve running passenger services on the section of the Powderhall Railway Line to the east of Easter Road. NR will not therefore be able to make any decision on the future use of this section of the Line, prior to TS deciding on whether to take forward any or all of these options for further detailed investigation.
In addition, the whole length of the Powderhall Railway Line is formally designated as a strategic rail freight link. This designation would have to be removed before NR could determine the line to be surplus to future requirements and allow its use for any other purpose.
Prior to doing this, NR would first have to undertake a statutory consultation process with all freight operating companies, who have a formal right to object. NR were unable to provide a timescale for how long this process could take but advised that it was likely to be lengthy. Officers requested that NR initiate this consultation process, to establish the position of the freight operators to the potential removal of the designation.
There is also a long-term lease in place between NR and the freight operator that formerly serviced the now closed Powderhall waste transfer facility. NR advised that they are unable to unilaterally terminate this lease and that, even if the operator were to agree to surrender it, the affected section of the line would still have to go through the consultation process described above and the lease would have to be offered to all other freight operators.
http://www.edinburgh.gov.uk/downloa...rth_east_locality_committee_business_bulletin
mcmad
11 Mar 2015
You have no idea how difficult it is to get something off the list once it has been designated a strategic site. All it takes is for one of the FOC's to raise an objection even if there is no real prospect of any freight running from the site again. The lack of stabling facilities around Edinburgh (see WCR's use of the Portobello maintenance area for stabling their 37) may be what scuppers this one.
Highlandspring
14 Oct 2017
Freightliner specialise in this; they nearly managed to entirely prevent the electrification of the Paisley Canal branch due to their objection to the Network Change on the basis of restricted access to the long abandoned Hawkhead fuel terminal.
Photohunter71
17 Jan 2012
In a flat beside Niddrie West junction
It looks like there are houses or some high rise structure built on or very close to the line as it runs by the Meadowbank shopping centre. I think it would be a good thing to keep the abbeyhill to meadowbank/Jock's Lodge section, but seeing there will be no future requirement for the Powderhall branch, then ultimately it makes sense to remove it. The Powderhall branch will in all essence eventually become a cycleway.
It's akin to the Leith branch from Portobello, there is really nothing that runs down there.
Ginaro
23 Aug 2016
Would they really need to use the entire line as a stabling facility, and not just say, the line to Easter Road?
och aye
21 Jan 2012
If the route past Powderhall hadn't been obliterated, there might have been a case to look at reinstating the line to the former Leith Citadel station.
But now that the Powderhall waste transfer station is no more, as others have said, there doesn't seem to be any point in retaining the line past Easter Road (for stabling) or Abbeyhill junction for trains to connect to Waverley as secondary/back up loop.
railjock
30 Jun 2012
Photohunter71
17 Jan 2012
With the waste transfer site gone, I would imagine that a cycle path is inevitable. However if network rail have improvement plans for the Eastern side of waverley station, surely retaining a good portion of the line is worth considering?
Emyr
8 Apr 2014
Funny things about housing developments is that people tend to need transport links...
Is there anything about this freight line which makes it unsuitable or awkward to use for passenger trains catering to the new residents of the former waste site?
Edit: having perused the maps, it looks like a rail service towards Granton Castle may be an option discarded a long time ago.
NotATrainspott
2 Feb 2013
There is no public transport need for the former Powderhall branch other than the section required for the Waverley eastern approaches capacity upgrade project. West of the Lochend Butterfly the line is best made a cycle path, similar to most other former suburban rail lines in Edinburgh. The city has one of the best bus networks and is extending/completing its tram network now, so there is no one asking for a rail service. Rail is only really suitable as a way for outer suburbs, exurbs and distant towns to retain a commuter connection into an urban centre that can provide graduate employment. As Powderhall is actually inside such an urban area, it's got nothing to worry about.
railjock
30 Jun 2012
Exactly right.
och aye
21 Jan 2012
There are long term plans to reconnect the Abbeyhill loop.
158756
12 Aug 2014
Is that still possible? Aerial pictures show new development at the former junction off the Powderhall line - have they left enough space?
NotATrainspott
2 Feb 2013
Yes.
https://edinburghcouncil.maps.arcgi...ndex.html?id=d1e3d872be424df5b89469de72bb03bd
This is the map that goes alongside the most recent Local Development Plan. It's a document that the council put out every once in a while and it sets out the guidelines for any major new developments planned in the council area. It's unusual for schemes to go ahead which weren't included in the most recent plan, and any developments that do go ahead will find it incredibly difficult, if not impossible, to then preclude other unrelated ideas in the LDP.
In this case you can see that the entire Abbeyhill loop is included in the LDP. The various local stations which used to be along this line, and the entire South Suburban line, are also included. Being in the LDP doesn't mean that something will go ahead, but in this case it would mean the council would have good reason to reject any proposals which prevented these stations being reopened.
The existing plans for future tram lines in Edinburgh are also included on this plan. Even without an active tram extension project or proposal, it will be almost impossible for someone to get planning approval which would block these tram routes.
Also on the map you can see the council has put the rest of the Powderhall branch as a future active travel route, just as you would expect. If NR did sell it up, then people wouldn't be able to buy little parcels of it and build things unless they provided for the active travel route to continue through.
