Llandudno
- Joined
- 25 Dec 2014
- Messages
- 2,213
Could you could board a southbound train at Oxenholme with a Penrith ticket if the train had not previously called at Penrith?
YesCould you could board a southbound train at Oxenholme with a Penrith ticket if the train had not previously called at Penrith?
Interesting, but aren’t there some examples were it’s cheaper to travel from a station further away?Yes
See https://www.railforums.co.uk/thread...1-ticket-types-conditions.70018/#post-1179615, for example. “starting short”.
I have heard that it can be cheaper from the likes of Lancaster to London rather than Preston to London, so could you buy a Lancaster to London ticket and board a train at Preston that hasn’t previously called at Lancaster?
I guess there must be similar examples across the network?
YesInteresting, but aren’t there some examples were it’s cheaper to travel from a station further away?
You may board a train at Preston that hadn't called at Lancaster (indeed some itineraries require a change at Preston), but you are not permitted to start your journey at Preston on a Lancaster to London Terminals SVR :I have heard that it can be cheaper from the likes of Lancaster to London rather than Preston to London, so could you buy a Lancaster to London ticket and board a train at Preston that hasn’t previously called at Lancaster?
The "except to change trains" part is nonsensical as a change of trains is not a break of journey.Break of journey is not permitted on the Outward journey, except to change trains.
https://www.brfares.com/!faredetail?orig=LAN&dest=EUS&grpd=1072&tkt=SVR
Would be very difficult to catch people; the only way I can think of to do it definitively would be to check all tickets on entry at Lancaster by putting in a revenue block there, and ensuring all e-tickets are scanned and paper tickets have some sort of special symbol inked onto them. Then block all the multiple entry points to the relevant platform(s) at Preston and ensure tickets have the relevant scans/inks on them.Though to be fair nobody will care if you do unless you do so at a time a Preston-Euston SVR would not have been valid. Preston is not gated, though special checks are I believe often done to catch people out doing it to avoid Anytime fares.
Incidentally the guard was not actually a "jobsworth"; a jobsworth is someone who does the job to the letter but without common sense. This guard did the job incorrectly, while also failing to apply common sense, making them far worse than that. However I would be surprised if appropriate action was taken and it wouldn't surprise me if the same guard is still behaving this way. I doubt Avanti have put in place the safeguards that Virgin before them lacked.Officers quizzed Mr Morrissey, from Blackpool, for more than 30 minutes until he was freed without charge after Virgin officials checked CCTV cameras and established he had in fact got on at Lancaster and had a valid ticket.
Indeed, southbound there would need to be some irrefutable way that the holder of a 3A restricted ticket travelling on a 2C restricted train can be shown to have not started their journey at the origin or that they had started it elsewhere.
Would marking all 3A restricted tickets on entry to Lancaster be sufficient, though? Someone using a, say, Arnside to Lancaster season in conjunction with the Off Peak ticket from Lancaster would be doing so legitimately but simply changing trains at Lancaster. Presumably their ticket would not be revenue blocked/marked and therefore deemed invalid from Preston if checked on one of the 2C restricted trains.
Not forgetting that an Off Peak ticket from Arnside to London, via Lancaster, itself has restriction 3A. Once tickets from Lancaster have been revenue blocked/marked there to close that potential loophole, would Avanti have to do the same at Arnside, etc, etc?
The approach is to catch the unsophisticated chancers of which there will be no shortage. Those who want to start short there and are aware of the block tactic at Preston will also have an answer ready. The difficult challenge for the revenue staff is showing that the passenger didn't start their journey at the ticket origin. Simply making one's way from elsewhere on the station onto platform 3/4 at Preston is not positive proof of that negative. To reliably prevent starting short there, using a ticket which does not permit it, the block at Preston would need to be on the entrances to the station.Someone who did come from say Arnside changing at Preston (most would change at Lancaster, though, so as to have more chance of a seat) would presumably be asked "how did you get here?" which would bring a sensible answer to those who had arrived by train
I'm not sure it would be easier but I'm wary of making the thread into an instruction manual for the determined to invalidly use the 3A tickets so will leave it at that.Catching it at Manchester Pic (the other place it'd be worthwhile) would be a bit easier because they could just do a block on 13-14 before the bridge and mark/scan tickets accordingly. Though you'd get away with it if you arrived there from somewhere else.
It's fairly clear in that case that they haven't come from a relevant station, unless such a train has just/recently arrived.Simply making one's way from elsewhere on the station onto platform 3/4 at Preston is not positive proof of that negative.
I wouldn't disagree. But, as far as you can trust the Mail's reporting of it, the guard in the linked article appeared more than "fairly clear" that the passenger hadn't come from the relevant station, so must have boarded the train at Preston. He was sure enough that despite the passenger's denials he had them detained.It's fairly clear in that case that they haven't come from a relevant station, unless such a train has just/recently arrived.
Boarding at Preston is allowed; it's starting the journey there that would be barred (though if the train had called at LAN then unless there were cancellations, changing at Preston would raise eyebrows)I wouldn't disagree. But, as far as you can trust the Mail's reporting of it, the guard in the linked article appeared more than "fairly clear" that the passenger hadn't come from the relevant station, so must have boarded the train at Preston. He was sure enough that despite the passenger's denials he had them detained.#
Some rail staff have a habit of making false allegations and I've not seen any evidence that TOCs have sufficient safeguards in place to ensure staff are "significantly more than "fairly clear" the passenger is breaching the break of journey restriction" before making accusations.Except that the passenger had started their journey at Lancaster, as CCTV later showed.
Doesn't a revenue block or ticket inspector need to be significantly more than "fairly clear" the passenger is breaching the break of journey restriction if they are going to prevent boarding or demand another ticket is purchased?
