Dougal2345
- Joined
- 29 Oct 2009
- Messages
- 578
The lines between Poole and Southampton Central are closed this weekend for engineering works.
Unfortunately the smaller stops are not being served at all by rail-replacement buses:
https://www.southwesternrailway.com...disruption-to-services-on-woe-and-south-coast
It's a bit vexing - having been 'trapped' in my village by the strikes the past two Saturdays, I was looking forward to a trip to-day - but after waiting half an hour for a bus at around 9 and trying again at around 11 (the one around 10 was showing as cancelled on Live Departure Boards), neither of which turned up, I headed home and put in for a ticket refund...
Due to a nationwide shortage of bus drivers, rail replacement bus services will be much less frequent than originally planned on Saturday 15 and Sunday 16 October with less overall capacity. This means that some stations will not be served or will have a more limited service, and there may be long gaps between buses at some stations.
Bournemouth Main Line:
On Saturday, engineering works will close the line between Bournemouth and Southampton. On Sunday, these works will be extended and will close the line between Bournemouth and Eastleigh. The line between Southampton and Fareham via Netley will also be closed.
On Saturday, due to a shortage of buses, SWR cannot confirm that all rail replacement services will run on Saturday. Services that do run are likely to be busy and customers should allow extra time for their journey.
On Saturday, there will be no rail replacement buses serving Pokesdown, Christchurch, and Hinton Admiral stations. Local bus services to Bournemouth or New Milton stations can be used to connect with rail replacement buses to Southampton but they will not necessarily stop at the stations themselves. Unfortunately, SWR tickets will not be accepted on these local bus services. You can find where local bus services are available here.
On Sunday, between Bournemouth and Southampton, a skeleton bus service will be in operation and may be very busy. Customers are urged to only travel if absolutely necessary and if they have to travel, please allow extra time for their journeys.
On Sunday, there will be no rail replacement buses between Southampton Central and Fareham via Netley, but there will be a normal train service between Eastleigh and Fareham via Hedge End.
A minibus shuttle will connect Sway to Brockenhurst to connect with other rail replacement bus services.
