Railway bridge over the M4, Bristol
Miles Smith
12 May 2024
Newport
The current bridge is blue(ish) and steel but apparently there was one before the M4 was built; does anyone have info/pics, please?
This bridge goes over the Old Gloucester Road, just to the south of the M4.
However, would it not just have been an embankment at the point where the M4 is? It seems odd that a bridge would have been necessary with no road beneath it, given the railway continues on an embankment north of the M4. Happy to be proved wrong though.
There are further bridges over Quarry Barton and the Bristol Road to the north of the M4.
Mcr Warrior
8 Jan 2009
Are we talking about the railway overbridge over the M4 about a mile to the East of Bristol Parkway station?
Gloster
4 Sep 2020
Up the creek
Looking at Google maps and streetview, the bridge over the Old Gloucester Road just east of Bristol Parkway and immediately west of the M4 is a traditional masonry bridge, probably dating from the opening of the line. Where the M4 crosses there was no bridge, at least on the 1938 25” map.
I think the original poster is effectively asking whether the bridge over Old Gloucester Road continued with spans to the north including where the railway line crossed the land where the M4 is now, or whether it was embankment. It seems that the bridges over Old Gloucester Road and Bristol Road are similar.
Benjwri
16 Jan 2022
Bath
No, the two bridges were separated by the embankment, part of which was removed for the M4. Both date back to the railway's initial construction in the 1900s.
Michael.Y
14 Oct 2011
Scroll down southwest a bit and you can see just how exactly Ashley Down is being built on the site of Ashleyhill
Miles Smith
12 May 2024
Newport
Thanks for replying. The bridge over the OGRd is quite high then when the line crosses the M4, it's much higher than the surrounding area. On a facebook site about Bristol I was told there was a brick bridge before the current one.
Miles Smith
12 May 2024
Newport
Yes. There is an old stone bridge over Old Gloucester rd and presumably another one where the M4 is now.
Thanks Gloster. So what did carry the line ie the OGrd bridge is quite high so there must have been something? Someone on facebook said there was an older bridge.
Mcr Warrior
8 Jan 2009
Looking again at the side-by-side OS map / aerial photo that @swt_passenger helpfully provided a link to in post #9, can't really see any other railway bridge in the exact same position where the motorway now passes under the railway line, more-or-less at right angles to the line.
So, was the railway line previously up on a section of plain embankment at this location?
DelW
15 Jan 2015
"Someone on Facebook" would appear to be wrong, as the old OS maps linked from this thread clearly show that there was no bridge there before the motorway was built, and indeed no reason for there to have been a bridge, as the embankment crossed an open field.
Quebec
7 Jan 2023
Kent
Yes, it was previously plain embankment. The distinctive steel bridge was added when the M4 was built in the mid-1960s.
Take it that the arched stonework bridge over the B4427 (Old Gloucester Road) hasn't ever been re-built/widened?
No it is a 3 arch bridge with quite wide arches (road only goes through middle arch, other two span sloping embankment.
This line was a late build, I think it was opened in 1903 and was built on big scale with gentle gradients for coal trains from Wales, hence the tall structures
Gloster
4 Sep 2020
Up the creek
Badminton-Patchway and Stoke Gifford-Filton opened for goods 01-05-1903. Wootton Bassett-Patchway and Stoke Gifford-Filton opened passenger 01-07-1903.
Source: History of the Great Western Railway, Volume II; MacDermot; GWR; 1931.
Miles Smith
12 May 2024
Newport
Don't know, looks original and old to me.
I tried posting the question on a Bristol-related Fb page but was refused and just told about the older bridge. Thanks for your reply; I've assumed that trains from S Wales went to London via Parkway and over the M4 but perhaps they went into T Meads and via Bath?
DelW
15 Jan 2015
When the Severn Tunnel was opened, the only connection on the English side ran via Patchway and Filton to Lawrence Hill, from where trains could either run into Temple Meads or take the direct curve towards Bath and London.
As noted above, the route from Wootton Basset via Badminton to Patchway, which now crosses the M4, wasn't built until the early 20th century. At what is now the site of the motorway bridge that line ran on an embankment across a field.
Parkway station didn't exist when that part of the M4 was built, it wasn't constructed until the 1970s.
Topological
20 Feb 2023
Swansea
Interesting
Presumably, this explains why the line goes straight (North to South) towards Bristol from Patchway station and the line to Bristol Parkway, despite being the main line now, is the one to curve away East.
DelW
15 Jan 2015
Interesting
Indeed so, this map shows the original line, with just the earthworks of the line via Stoke Gifford and Badminton added, marked as "Railway in the course of construction".
What I don't know is, after the Badminton line opened, what proportion of south Wales to London passenger services used it compared with those still going via Temple Meads, so that they could serve Bristol as well. The Badminton cutoff was very useful for goods trains, including the lucrative coal traffic from Wales to London.
Until the 1960s, trains running from south Wales to London via Temple Meads could still have been competitive for speed with the road alternatives. Those would have been either driving via Gloucester and the A40, or using the car ferry across the Severn estuary then the A4 to London. Very few bypasses then either, so it would have been a long slog.
