You can look up most of the SBB trains for yourself on the Swiss Kursbuch timetable PDFs website (Fahrplanfelder.ch) and on 'Reisezuge.ch' website which gives train formations and where you can search by various parameters, including train number.
It's a bit late at night now as I respond to this but I'll quickly throw in what I can in the time available before I have to turn in...
Looks like you've (Perhaps inadvertently?) picked lots of DB ICEs and ICN tilting EMUs, where alternatives exist on the same or parallel routes. I wonder if that's what you really want. May I suggest researching further using the two websites given above where you might be able to find more 'interesting' train types to ride on.
I have now written a plan. I will be going in August. Could anyone please make recommendations/amendments to my plans and also provide types of classes for the train legs?Thank you for your help!
Friday
Zurich HB 7:37 Konstanz 8:54
460 + EWIV push pull
Konstanz 11:12 Schaffhausen 14:45 (Boat)
Schaffhausen 15:21 Schloss Laufen am Rheinfall 15:26
Flirt EMU I suspect
Schloss Laufen am Rheinfall 16:26 Winterthur 16:54
Flirt EMU I suspect
Winterthur 16:58 Zurich HB 17:23
ICN unit (no detective work needed here as train number 'ICN1530' and timetable PDF tells you in any case
Saturday
Zurich HB 8:07 Chur 9:22
DB ICE
Chur 9:56 Disentis/Muster 11:11
all trains on this line booked hauled stock (non push pull) + Ge4/4II
Disentis/Muster 11:14 Andermatt 12:22
hauled stock with MGB Deh4/4 or HGe4/4
Andermatt 12:37 Visp 14:50
usually MGB Deh4/4 hauled
Visp 15:06 Lausanne 16:45
Re460 + EWIV (push pull on this line since Dec 2015)
Lausanne 17:15 Zurich HB 19:30
ICN1533 tilting EMU via Neuchatel, Biel/Bienne
Sunday
Zurich HB 7:32 Bern 8:28
460 + IC2000 double deckers
Bern 8:34 Interlaken Ost 9:28
DB ICE
Interlaken Ost 11:04 Luzern 12:55
ZB 'plastic' EMU
Luzern 15:12 Fluelen 18:03 (Boat)
Too late in the day for a paddle steamer southbound - are you happy on a diesel boat?
Fluelen 18:24 Zurich HB 19:28
At last - something you might really want! - Re4/4II + Rare shorty 4 coach sundays extra
Monday
Zurich HB 7:07 Chur 8:22
Re460 + EWIV, IC on this route mainly hauled 460
Chur 8:58 St Moritz 11:03
all booked Ge4/4III
St Moritz 11:48 Tirano RhB 14:19
probably Allegra unit but check using the train number and RhB's published loco diagrams
Tirano RhB 15:00 St Moritz 17:11
probably Allegra unit ditto above
St Moritz 17:57 Chur 20:03
normally Ge4/4III
Chur 20:09 Zurich HB 21:23
DB ICE
