My thoughts exactly.4 minutes is do-able if you aren’t infirm. However I’m guessing you’re going for an Ilkley train so if you do miss it for whatever reason you only have half an hour to wait for the next one.
If the OPs train from Carlisle is late, perhaps gong via Leeds may save minutes. But i dont know if his ticket would allow it.4 minutes is do-able if you aren’t infirm. However I’m guessing you’re going for an Ilkley train so if you do miss it for whatever reason you only have half an hour to wait for the next one.
Certainly is. Far better than the woeful effort on the Natiinal Rail website.Is it worth the OP looking on Google Earth to get a birdseye view of Shipley station?
Yes, if you are a good walker, 4 minutes is doable. Off the train, over the footbridge. Turn right. Then cross the car park and turning area with the station building to your right and at the end of the station building will be a gap.
Probably not a problem for your journey but just a heads up that the current May 22 timetable will make Bradford-Ilkley hourly.
Also, depending on the time of day, the footbridge and the footpath across the car park can get busy (though I did make 3 to 2 in one minute recently against the tide!). Cutting across the car park itself is shorter but less safe.Thanks for all the helpful replies, that I couldn't have got just from google maps. I forgot to mention that I will have a small toddler in tow, so we'll be lucky if we make it in 4 mins!
That's a shame as it will make future journeys more difficult.
There is an alternative route with fewer steps - I have never tested it but it is approximately the same distance: alight from the very front of the train, down the steps, cross Station Approach carefully and turn right on the footpath alongside P3.
Not tried it, as TBH it only occurred to me because of your question.this actually looks a lot simpler to be honest, just checked on google streetview. especially with a pushchair. according to my calc it's 200m as opposed to 190m over the footbridge!
I tested the route via the footpath, P2 and footbridge last night, and it took just inside 2min. Someone cutting across the car park was quicker, and I am a brisk walker!
I'm suprised that up and over a footbridge is quicker than down some steps + a straight pavement. Or did you mean to write that the other way round?
