Poggs yes I am after signalling control tables. I am approaching the signalling design companies to see if we can get the electronic files. I am after a national set of electronic data. Yes c70k control tables worth of data.
It all depends what you intend to use the Control Tables for, can you provide more details. Don’t forget each Control Table is bespoke for each Signal, Route, Point No. etc, using a generic standard format.
First a word on process. NR Contract with a number of suppliers, some may just do design, some may even only do the design up to the Control Table with others doing the detailed Interlocking design etc. At the end of the Contract the supplier will hand over the Control Tables as ‘finals’ to NR with NRG having overall responsibility for long term safe keeping. From time to time NRG will release the design to the same or another supplier for reference or for modification as part of ongoing works, for the purposes of safety only one organisation can be the ‘design authority’ at any one time.
Looking at the Control Tables themselves, these were traditionally hand drawn, with transfer to Computer Aided Design (CAD) about 30/35 years ago. Unless things have changed since I retired four years ago most Control Tables continue to be produced on Microstation CAD, but these are essentially just a drawing with no extract facilities.
One of my colleagues at Chippenham developed a method that required the track plan to be redrawn in a schematic format that had extract facilities from which Control Tables and then SSI/Westlock data could be automatically generated. How extensively this is used I don’t know.
I am still baffled why CAD is still used for a tabular document, I successfully used Word for Oslo T-Banen from about 1995,and I have seen Excel used elsewhere.
Conclusion: I think you the best you will get will be scanned files, extractable data format probably doesn’t exist (more than happy if anyone can confirm otherwise).
