SouthEastern franchise direct award through to 10 November 2019 (optional extension to 1 April 2020)
Discussion in 'UK Railway Discussion' started by Stow, 11 Dec 2018.
  1. LeeLivery
    LeeLivery Established Member
    1,036
    13 Jul 2014
    And people in deepest Brexiteer Kent said EU law never helped them...
  2. Barn
    Barn Established Member
    1,400
    3 Sep 2008
    That's right, although the numerous extensions are themselves on the very edge of legality.
  3. Metal_gee_man
    Metal_gee_man Member
    218
    28 Oct 2017
    Thinking about it 2tph into each platform which is all I'm proposing will be very achievable because the intended turn around time would be between 15/20 minutes before it returns on the same route, or even shorter if the Ramsgate service then turned into a Dover or Faversham service meaning turnarounds could be shortened even further if required to free up platform space (I don't see the need for it but its an option)
    But hey its a pipe dream to see a total of 4tph (including the 1 Charing Cross and 1 Victoria services) in each direct via Canterbury West because of the disruption it'd cause with the level crossings on that line
    There shouldn't be a problem doing that from Dover upping the service to 3tph (including one Charing Cross service) via Folkestone
    And Faversham already handles 2tph to St Pancras (one circular, one starting there) so there are no problems with paths there
  4. hwl
    hwl Established Member
    3,308
    5 Feb 2012
    A TVM430 module is available as a drop in module (as TPWS is) for ETCS too. so arguably easier now than earlier as you would need to match the original batch. New trains are effectively built with ETCS at the core and other signalling systems added on (See Aventra delays)
    Ultimately HS1 is going to be converted to ETCS as has already started happening in France.
    Probably looking at 9x 6car units to sort out the HS1 service.
  5. Wolfie
    Wolfie Established Member
    2,101
    17 Aug 2010
    Yup, you are absolutely right
  6. Jimstar
    Jimstar Member
    30
    22 Jan 2019
    SE extension confirmed to 10th a November, with option to 1st April 2020.
  7. Geogregor
    Geogregor Member
    32
    16 Sep 2016
    Yep, just got email confirming it.
  8. ComUtoR
    ComUtoR Established Member
    5,400
    13 Dec 2013
    Unless the franchise gets awarded, this almost guarantees the extension will run till April. This is not good for anybody. I hope that the agreement is more than just money and that there is something that starts the process to introduce new stock. I am not looking forward to another year of stagnation.
  9. KingJ
    KingJ Member
    117
    23 Dec 2012
    The extension confirmation is buried towards the end of this press release
    https://newsroom.southeasternrailwa...-introduce-15-minute-delay-repay-compensation
  10. urpert
    urpert Member
    855
    1 Dec 2015
    Zone 4 or between Étaples and Rang-du-Fliers
    From the press release it sounds like Delay Repay 15 and some tweaks to the website are the only ‘improvements’ we can expect before next April.
  11. ScotGG
    ScotGG Member
    901
    3 Apr 2013
    Same old same old. Another year kicking the can. Good old DfT.
    Worst treated franchise in the south east of England? Kent routes are ok but Metro is so far off the potential it has
  12. 3141
    3141 Established Member
    1,329
    1 Apr 2012
    Overton, Hampshire
    The DfT has got itself into a deep hole here. Govia obviously won't invest much into a franchise that it may not be running after November, or after next April. If the DfT wanted to order new trains it would surely have to publish a notice inviting tenders, the winner might not be what the eventual winner of the franchise would have ordered, and the trains wouldn't arrive till late next year or more probably in 2021. Or if the DfT instead planned to bring in stock that's going to be displaced (such as 458s or 707s) they too might not be what the eventual franchise winner would choose, they are unlikely to be available in time (unless there's at least one more extension after next April), drivers and fitters would have to be trained (an expense that the present franchise holder wouldn't want to undertake if they might no longer be running the show), and anyway there aren't enough sidings to park them. On top of that, the two remaining bids for South Eastern are now several months old and would have to be renegotiated before an award could be made.
  13. Geogregor
    Geogregor Member
    32
    16 Sep 2016
    Yep, spot on. Nothing will happen regarding rolling stock. Probably for years...
  14. Bromley boy
    Bromley boy Established Member
    4,391
    18 Jun 2015
    According to some contacts of mine who work there, the news of this latest extension has been badly received internally. Morale at SE metro driver depots is apparently not good, and getting worse. Other TOCs in the area offer better work, or better pay/conditions or both in some cases! SE pay is now far behind where it should be, with no new deal likely for another year.
    Those drivers who can are leaving in droves, either to SE mainline depots for better work, or to other TOCs, with many currently working their notice periods. One metro depot in particular recently suffered a recent mass defection of almost 1/3 of its drivers and is now well under establishment, with much of its work having to be cross covered by other depots.
    Those not looking to leave are often trapped by poor safety records - in part because of variable instructor quality. DIs range from fantastic to some who are completely wrong for the role, and doing it for the wrong reasons. This is because few drivers are willing to instruct given the poor additional pay for a great deal more risk and hassle.
    Of course these issues are by no means unique to SE but, from what I’ve been told, this succession of short franchise extensions comes at a very bad time.
  15. bionic
    bionic Member
    586
    8 Nov 2013
    You've only got to look at how many drivers expressed an interest in working for GTR when the flyers appeared. It was like Black Friday! :D
  16. Bromley boy
    4,391
    18 Jun 2015
    A twilight zone version of Black Friday, where the store actively turns away its most desperate shoppers :D.
  17. ComUtoR
    5,400
    13 Dec 2013
    And the weird universe where the most qualified ones (who are more qualified than their actual Drivers) DONT get the job. !!
  18. Aqua97
    Aqua97 New Member
    1
    Sunday
    Your contacts indeed do speak the truth. Every word here is true. A shake up is what we were hoping for but yet another 9 months now.
  19. fergusjbend
    fergusjbend Member
    140
    11 Sep 2011
  20. urpert
    urpert Member
    855
    1 Dec 2015
    Haha you had me for a minute there!
  21. 700007
    700007 Member
    936
    6 May 2017
    Near a bunch of sheds that aren't 66s.
  22. HH
    HH Established Member
    3,989
    31 Jul 2009
    Essex
    The extension will be called. There will be no new rolling stock. DfT are now paranoid about legal challenges, so everything has to go through the lawyers and 7 tiers of (mis)management, so the wheels are grinding exceedingly slowly.
    BTW LSER drivers are not so badly paid, unless you compare them to GTR - unfortunately they live next door and drive some of the same trains.
  23. Shug
    Shug Member
    30
    23 May 2017
    They are also paid less than drivers at cross rail, LO, and Southern. The main issue is pay deal was due 2018 and could not be negotiated due to last year franchise (allegedly) and the same is happening this year. So are drivers going to remain at SE with no realistic prospect of a pay deal for a considerable period when their neighbors are paid more, I think the GTR difference will be close to £15k by October especially at Orpington as they do GTR work and get no enhancement
Share This Page
