Southern Formation Changes Once The Class 313s Are Withdrawn.
PGAT
13 Apr 2022
Selhurst
It looks like the rest of the network won’t suffer too much, except for East Grinsteads not running 10 coaches to free up the 377/3s
physics34
1 Dec 2013
Yeh i think barring a couple of peak time trains, grinstead could be 6 car off peak. Certainly dont need to be 10 or 12 off peak and weekends
PGAT
13 Apr 2022
Selhurst
Also cutting back the 1GXXs to Eastbourne saves some a couple of 4 car units to be used elsewhere
WizCastro197
12 May 2022
Reigate
As per the 455 withdrawal, it is now fairly obvious there will be a repeat of service cuts and/or formation changes, in order to release more 377s for coastway services when the 313 retirement comes around in May. What services could potentially have their formations shortened or services truncated? I have pulled some suggestions from another thread:
Would Portsmouth & Southsea/Southampton Central and Bognor Regis splitters/attachers be perhaps reduced to 8 coaches throughout the day, to save a couple 4 coach units? Could those 4 coach units be then substituted for 3 coach 377/3s on metro services, which then allows them to work on the Coastway?
What other services/formations could be reduced?
PGAT
13 Apr 2022
Selhurst
Southampton and Portsmouth splitters are already 8 coaches outside the peaks.
Not much cuts would be needed. What’s most likely is that all the 313 diagrams are replaced by the 377/3s which Southern have “surplus” of right now. When all the 377/3s transfer routes it shouldn’t have a massive effect on the network. The only change necessary is to get rid of the 4+3+3 formations on the East Grinstead route as previously stated.
RobShipway
20 Sep 2009
So the 377/3's are going back to their original routes?
Minstral25
10 Sep 2009
Assume you mean to drop East Grinstead from 10 to 8 car (i.e. 4+4) to release the 3's for the 313 duties - question is where are the extra 4's doming from - tightening up of duties again? Such as Peak 12 car services reduced to 8 car perhaps?
WizCastro197
12 May 2022
Reigate
Can Littlehampton peak services lose a 4 coach unit off the end, reducing it to 8 coaches? I have no idea how busy these services get, so I feel a little bad proposing dragging off a unit when the capacity may well be needed.
busestrains
9 Sep 2022
Salisbury
With the 313s being gone soon and the 455s having left not long ago i reckon the number of twelve coach trains will be further reduced. I am not sure how many will still run but i can definitely see less twelve coach formations running and more peak hour overcrowding. Southern really need all of the 377/5s from Southeastern soon.
PGAT
13 Apr 2022
Selhurst
Looking at the timetable it's clear the 377/5s won't be coming from May and at this point even December would be dire. I believe there are no 12 car trains running off-peaks except maybe for the East Grinstead trains.
nw1
9 Aug 2013
Was 4 car on electrification in the 80s but admittedly that was with a half-hourly service. Hard to know whether off-peak usage is higher or lower than in 1987, as there seem to be so many conflicting reports about this.
