weeklycommuter
- Joined
- 2 Feb 2019
- Messages
- 524
Southern - West Coastway timetable changes
Engagement on proposals
As part of our commitment to supporting your journeys, we have developed some proposals to change Southern services on the West Coastway from 2024.
From Download our document
This would change our services across the West Coastway, the route between Brighton, Worthing, Chichester, Portsmouth, and Southampton and services to London Victoria via Horsham.
The proposals refer to Southern services running Monday to Saturday on our West Coastway route. There are no changes proposed for Sundays.
Our proposals for West Coastway services are designed to improve reliability and make journeys, especially those over longer distances, more attractive, with space for customers where it is needed most.
There are changes to all services on the route, but the focus is on regional services from Brighton, longer distance services to London Victoria via Chichester and all-stations services along the coast.
Longer distance services will be redesigned. Rather than the current split between the cities, in the future both London Victoria via Horsham services will serve Portsmouth Harbour only, connecting to the ferry port and Gunwharf Quays, with both Brighton services serving Southampton only, providing connections for journeys into the west of England.
For both services this will mean improved regular intervals between trains at a new half-hourly frequency. It will create slightly faster journey times between Brighton and Southampton and will help to improve the reliability of Portsmouth Harbour to London Victoria services by creating a longer turnaround time. The proposed timetable has been designed so that Chichester or Barnham will provide a same platform interchange between services.
Longer distance services are also provided by Littlehampton to London Victoria via Worthing services. These are not proposed to significantly change outside of being increased to half-hourly all day with additional calls at Lancing.
A new half-hourly Brighton to Chichester via Littlehampton all-stations service will run, providing extra capacity on the busiest section of the route into Brighton and simpler shorter distance journeys.
To make this change, the hourly all-stations Littlehampton to Portsmouth & Southsea service will be removed with smaller stations between Portsmouth and Chichester, such as Fishbourne, then divided between the two Portsmouth Harbour to London Victoria services. One train will serve Fishbourne, Nutbourne and Warblington, with the other serving Bosham and Bedhampton.
This will provide direct services to and from Gatwick Airport and London Victoria as well as retaining direct services to and from Portsmouth Harbour at the same frequency as today. Frequencies between Bognor Regis and Barnham will not change but the proposal is to create more even intervals between departures of approximately every 15 minutes by running two services to London Victoria and two shuttle services to and from Barnham.
We are adding a stop at Woolston to integrate with the very frequent bus service to access most parts of Southampton City Centre faster than can be achieved via Southampton Central.
The proposals in this document would require some related changes to South Western Railway services. These are mainly, but not limited to, the re-timing of trains and would only be introduced if the main Southern proposals are taken forward.
