unit mileage constraints. One example I remember seeing in the CWN was a 12 450 coming in on a Poole semi-fast (2Bxx) running empty to Clapham, then a separate 12 450 coming in from Clapham to form the Portsmouth via Eastleigh 1Txx which would in the standard pattern have been formed from the incoming Poole.
Not only unit mileage constraints, but there was also extreme pressure to reduce crew diagram costs, and these factors combined with an increase in patronage (at the time), but also the restraints of the (19) platforms at Waterloo at the time, would all have had an impact on decisions made in the planning process.
As regards the 12 car 450 swap (Waterloo to Clapham and back), I do vaguely remember that, but don't now have the documents that would allow me to answer the reason(s) for same.
As you have posted that detail and perhaps having caught the attention of others to question 'why' (etc?), I would welcome the chance to explain same.
If you have the entire perm (base plan) CWN for that period, and can let me have sight of, I may be able to answer the reasons for that move. But I would need the full document in order that I might be able to re-write (in the here and now) the diagrams of each of the six class 450's involved in order to understand what was done at the time. It may have been the result of unit mileage restraints, Waterloo platform restrictions, and/or something crew related, but to stand a knat's chance of answering, I need to have all the detail.
PS;
A follow up for nw1: ref previous post. The 12 car 450 swap was for CET (toilet tank) emptying purposes. The unit diagrams concerned if not swapped out, would have resulted in some of the units concerned not being serviced for longer than was required, so done for the benefit of the passengers.
