'Tangmere' failure on Cumbrian Mountain Express today - 21st September
12LDA28C
14 Oct 2022
The back of beyond
It seems that 34067 'Tangmere' failed in serious fashion at Ormside on the return leg of today's CME (1Z87 1418 Carlisle - Euston) with a detached piston rod and pierced cylinder. The train was taken back to Carlisle by 47802 although it got no further, being cancelled there with tour participants heading home on Avanti services.
YorkshireLass
17 Oct 2012
Can confirm. Tangmere detached from the train and dumped in a siding at Kirkby Stephen. 47802 took the train back to Carlisle but was found to have incurred wheel damage in a tunnel on the way back to Carlisle. 86259 summoned from Preston to take the train back down South but with 47802’s wheel damage the train would not be permitted to exceed 60mph, therefore passengers decamped to the Avanti service to get home the same day we set off.
peteb
30 Mar 2011
I was following this on real time trains. After detaching Tangmere did the train go to Hellifield then back to Carlisle? RTT suggests it did but in that case I wonder why it didn't go to Carnforth from Hellifield?
12LDA28C
14 Oct 2022
The back of beyond
There was no path available to Carnforth due to late night engineering possessions I believe.
YorkshireLass
17 Oct 2012
Train went back from Kirkby Stephen to Carlisle after detaching Tangmere. NR wouldn’t let the train leave until Tangmere had limped into the siding. Train couldn’t continue to Hellifield as there was no way to get 47802 on to the front of the train at Kirkby Stephen (or so we were told) hence the need to go back the way we came.
merry
19 Oct 2011
Whilst there are crossovers at both Kikby Stephen and Appleby, a run round of the diesel would have involved two wrong direction moves through the block sections. It takes time to set such moves up and control authority is required as it is an emergency-only action. An MoM might also be required. So the line would have been blocked for a longer time, making a return to Carlisle preferred, and perhaps the wiser choice.
Wyrleybart
29 Mar 2020
South Staffordshire
It went back to Carnforth as 5Z67 hauled by 47802
Incidentally the youtube videos of this move seem to be scurrying along with no "clatter" from under 47802. I am wondering whether WCR had a fitter or techie at Carlisle to check 47802 over to see if it did sustain any damage.
Harvester
9 Nov 2020
Notts
How times have changed since 1980 when Leander was stuck at Kirkby Stephen on a southbound CME, some way behind failed 40179 on an up freight. BR allowed Leander to detach, cross over and run wrong line to get ahead of the failure. After crossing back to the up main 5690 reversed back, hooked up to 40179 and hauled it and the freight south to a siding at Garsdale.
merry
19 Oct 2011
A slightly different scenario in 1980; Leander will have been an assisting engine (run as 1Z99), in one of the exact scenarios for which wrong line working rules are designed. Not permitted for convenience... which is what running round constitutes.
Whilst there is another way to do the run round (shunt the train to down platform, run round right line), that might have required detraining all passengers (because the trailing crossover will usually not have facing point locks) and blocking the down line as well for a half hour minimum.
Whatever solution was used, it would be operationally messy. I reckon the chosen solution this time was, sadly, the most robust and simple operationally, even if boring and disappointing.
Worth considering how the delay affected available crew hours too, continuing might have pushed too close to the maximum.
david1212
9 Apr 2020
Midlands
Why would the train not been permitted to run at more than 60mph if hauled by 86259 from Carlisle to Euston?
The possibility of wheel damage also to the stock?
skyhigh
14 Sep 2014
Risk of damaged wheel damaging the track. It is a rule book instruction. (Assuming the defective loco would have gone with it).
david1212
9 Apr 2020
Midlands
Because 47802 would have been on the rear of the train to Euston.
I was presuming that with 86259 hauling 47802 would not be required.
Following on if 47802 was on the outward leg from Euston rather than added at Preston and Tangmere had not failed for 47802 around 450 miles of planned dead running plus the ECS mileage.
Mcq
24 May 2019
Anybody know what the plans might be for this much loved engine?
Mcq
24 May 2019
I see from RTC that "This special steam hauled with locomotive No. 34067 Tangemere, will run at speed both ways from York to Edinburgh and return. There will be time in Edinburgh to visit the sights, including the extensive Christmas Market located in Princes Street Gardens, before we return south." next Saturday!
Someone's been working hard at Carnforth - any info welcome
Bertie the bus
15 Aug 2014
That is just someone not bothering to update an advert. The front page of their website states a "Carnforth pool locomotive" and one of the railtour listing sites states 44781. The tour is only 4 days away, if it was to haul it it would have performed at least one test run by now.
Mcq
24 May 2019
That was last Saturday.
Let's see.
Bertie the bus
15 Aug 2014
What was last Saturday? As I said RTC's website states "Carnforth pool locomotive" for the tour you linked to:
It is only the advert for the tour that says Tangmere, well it actually says Tangemere, and that is just laziness.
There is absolutely nothing to wait and see.
bleeder4
19 Jan 2019
Worcester
Here's the loco and stock move today from Carnforth to York, ahead of tomorrow's tour.
Still expected to be Tangmere, according to all the info I have from RTC.
Wyrleybart
29 Mar 2020
South Staffordshire
Has there been any evidence of a test run of Tangmere with it's "new" cylinder. They normally have a trip out over the "Little North Western" don't they ?
