truckman060473
ok so a diesel electric loco has one huge engine driving an alternator which feeds the traction motors. sounds simple enough. but is there anything else taking place here that allows the loco to have such a wide speed range? (an articulated lorry may have 18 or more gears) ok so we know the loco has no gear change since there is one pinion on the traction motor driving one large spur on the wheel axle so the ratio can't be altered. so if we look at the electrical machines - the alternator; does this have a switching system, lets just say for arguments sake, it may have two main windings which are switched in a parallel set up for lower voltage high current that applies when the train is moving off and when the train is up to medium speed the windings are switched to series for more voltage allowing the loco to gain 70mph+. i may be wrong and this does not occur (although i have heard of this principle in electrical engineering), but i have noticed when watching DVD's of cab rides that with a class 37, when it has reached about 30-40mph there follows a change in engine tone as if the load on the alternator has increased.
