Timetable planning: How to/software
03_179
13 Aug 2008
At my desk
Hi all,
I was wondering if anyone know what software is used to plan trains timetables ?
Also a How to pdf guide on how to plan trains along a line?
Thanks in advance.
Software is available but you'll need very deep pockets.
It is possible to do simple-ish timetables by creating train graphs in Excel. This is a time-distance graph where each train appears as a line so it is reasonably easy to tell where they pass, overtake, try to use the same track, etc. It does get pretty complicated once junctions are included though, and Excel wasn't really designed to do this so it takes quite a few bodges to make it work.
306024
23 Jan 2013
East Anglia
There are many different types of software in use around the world, but they are all specialist bespoke systems depending on requirements and how they interface with other systems. Nothing to cater for the 'enthusiast' market so far as I am aware.
In the UK leading systems are NR's TPS (imaginatively titled Train Planning System) for timing, VoyagerPlan, used mostly by TOCs for timing and resourcing, and TRACSIS who supply resource planning systems.
03_179
13 Aug 2008
At my desk
Thanks for the info gents.
Looks like it's the excel version for me.
So:
the Vertical axis is the stations?
the Horizontal axis is the time?
Train1 is a line stating at the bottom left hand corner and is a line going up to stations in the time allocated?
306024
23 Jan 2013
East Anglia
Simplistically yes. Train 1 could start in the top left corner if it is coming in the opposite direction, you can graph both directions on the same graph.
If you want a bit of practice, a good example would be to try to graph the East Suffolk line from Ipswich to Lowestoft. The working timetable is available on the Network Rail website, but for simplicity it may be easier to use the public timetable. You'll see how trains pass at Beccles, and don't pass on the single line sections (obviously ;) )
03_179
13 Aug 2008
At my desk
Superb.
Thanks a lot guys. I hope to put something together and when I do I will post what it looks like. Gimme a few weeks though lol
Sorry to ask chaps.
When I have a train that stops for a couple of minutes (i.e. Battersby where there is a reverse) how would I show this?
23 Jan 2013
East Anglia
That would simply be a horizontal line for as many minutes as it waits there.
It is helpful to give some thought about the scale you wish to use for the axis, otherwise your graph will look too wide or too tall.
03_179
13 Aug 2008
At my desk
I will do all the stations (and major points that are listed in the WTT) and acrss I will do 30 minute spells to start with.
If you're using Excel you need to start out with an X-Y scatter graph and work from there. I have produced one myself but unfortunately can't circulate it as it is the property of my employer. Plus people have to have a couple of days training before they can work it!
JRM
11 Mar 2015
Keighley, W Yorks
For fifty years I have been playing fantasy timetables, using computers for the last 40. Never finished anything! Lots of scraps in long-forgotten computer languages.
I'd be interested in sharing ideas with anyone who wants to develop home-brew software.
In particular, I'd love to get hold of digital gradient profiles. Does anyone have any? I have half-finished software to scan graphical gradient profiles and digitise them if anyone wants to encourage me / help me to finish it. Although this is less relevant now, when modern trains have enough power and kinetic energy to flatten all but the longest, steepest climbs.
Anybody else out there interested?
Gradient isn't specifically used in timetabling software. It is considered when calculating running times which are either derived from old TRATIM tables or calculated via Railsys, VISION, and empirical data such as stopwatch or OTMR.
03_179
13 Aug 2008
At my desk
What languages have you been working in?
JRM
11 Mar 2015
Keighley, W Yorks
I work mostly in Excel/VBA and Delphi now. I am only an amateur, but I've been programming since 1968 and have worked in more languages than I can remember.
03_179
13 Aug 2008
At my desk
I have produced a lot in Excel over the years.
Wondering if it is possible in Delphi, java, VB etc.
My lad is a bit of a whizz at computers I could ask him.
rf_ioliver
17 Apr 2011
I wrote mine in Prolog so that I could let it do much of the calculation. I even wrote a route finder as well :) The problem here is that the libraries to interface with other languages were pretty poor.
The actual timetable is relatively easy once you've sorted out the data structures and the level of detail you want. Forget any SQL vs NoSQL debate, this is good old fashioned computer science, E-R modelling stuff.
I did this for one of my Train Simulator routes...actually, it was setting up the routes in TS to get the timings at stations and certain points, e.g.: junctions is the p**a.
t.
Ian
