Legolash2o
- Joined
- 27 Sep 2018
- Messages
- 668
What sort of information does TOPS (Total Operations Processing System) contain about rolling stock? I.e. length, weight, brake force, others?
Thanks
Thanks
stuff™
In hindsight an FKA twin probably wasn’t the best vehicle to use as an example but it’s what I had immediately to hand. What that is twlling you is that the wagon is RA1 when in tare condition, RA5 when loaded to maximum possible weight and is running RA2 at the time of the enquiry. I could have a go at annotating it if that would be of any help?On that TOPS enquiry. If I'm reading it right (I know nothing about TOPS) Why would it show as RA1 RA3 and RA5 ? I sorta understand the RA1 and RA5 as it states No. of units 2 so I get that they may have different availability etc but then it states RA2.
Cheers in advance.
Tare weight (empty) 48.6T is RA1
Gloss (max GLW) 136.6T is RA5
Current Data (actually loaded to 105.6T) is RA2
RA route availability equates to axle load. Larger the RA, higher the axle weight.
TOPS is a 70's programme, that is still used today, one reason being there is not a lot, if anything that can beat it ! TOPS will tell you absolutely everything you need to know about a wagon, coach, loco, train formation, what the train is carrying, how long, how heavy, if there are any Dangerous goods and what they are.....
Couple of points about TOPS;
It does not give a comprehensive list of dimensions or maintenance history, for example.
The changeable information is input by a human. It can be wrong.
...info only as good as the person that input it in the first place![]()
Absolutely. Although it leans more towards ERIC this RAIB report illustrates the pitfalls of failing to understand the safety implications of the information in the IT systems we use every day -Put another way, On the Railway it is a safety critical tool, not a trainspotting aid.
