nanstallon
- Joined
- 18 Dec 2015
- Messages
- 968
If I buy a Devon Ranger ticket to travel from Plymouth to Taunton, buying a ticket from Tiverton Parkway to Taunton as an add on, can I travel on a train that doesn't stop at Tiverton Parkway?
I’m not sure that’s right for a day Ranger ticket.As one of the tickets you are using is a rover there is no requirement for the train to stop at the station which you change from one ticket to another.
From the Conditions:I’m not sure that’s right for a day Ranger ticket.
if you are using a Season Ticket, daily Zonal Ticket, or another area based Ticket such as a concessionary pass, ranger, or rover, in conjunction with another Ticket and the last station at which one Ticket is valid and the first station that the other Ticket is valid are the same, then the train does not need to Call at that station for your combination to be valid.
Fair enough, I’m not in a position to check for myself, which is why I said I’m not sure.From the Conditions:
The NRCoT are, by definition, publicly available so I'm not sure how you would have been unable to check?Fair enough, I’m not in a position to check for myself, which is why I said I’m not sure.
At that immediate time. I don't carry a copy around with me.The NRCoT are, by definition, publicly available so I'm not sure how you would have been unable to check?
I think he was otherwise engaged despising of a TVM at the time
