Trivia: disused/dismantled railways in the UK with signals still in situ
Harbornite
7 May 2016
I was thinking about this after exploring the Grimsby-Louth line on google maps and finding an old semaphore post. Other examples that spring to mind are the Penmaenpool home and distant (albeit with an unoriginal arm) and the signals on the mothballed Dudley- Walsall route which is now being cleared. How many other examples can you think of where there are surviving signals or signal posts on disused lines (preferably on lines that are dismantled and can be walked).
Thanks.
61653 HTAFC
18 Dec 2012
Before it was turned into a cycleway, the Spen Valley line between Dewsbury and Ravensthorpe had no track but did have illuminated colour light signals visible from passing Huddersfield to Leeds trains!
tsr
15 Nov 2011
Between the parallel lines
There are at least one or two ground position light signals at Selsdon for the disconnected lines on the disused branch platforms.
As I understand it, any removal works are deemed more disruptive than leaving the disused signals functioning and in situ.
The long-dismantled Newport Pagnell branch still has a signal post extant by the site of the old Newport Pagnell station.
pompeyfan
24 Jan 2012
There's a proud looking semaphore on Hayling Island, just before the bridge on the long gone Hayling Billy line.
Ianno87
3 May 2015
Potton station (on the former Varsity Line between Sandy and Cambridge) still has the remains of a semaphore post alongside what's left of the old station.
Tim R-T-C
23 May 2011
At Ballachulish up in Scotland there is a signal by the road from the line closed in 1966
ChiefPlanner
6 Sep 2011
Herts
Parts of the Croxley Green branch did for a while - track was "borrowed" in July 1996 to urgently repair the WCML after the collision ...
Railsigns
15 Feb 2010
That signal was moved there from Fort William in the 1980s (it was the Mallaig Junction Up Branch distant signal).
physics34
1 Dec 2013
they even renewed it with LEDs!!!
Deepgreen
12 Jun 2013
Gomshall, Surrey
I recall when the up West Croydon to Victoria fast lines connection at Windmill Bridge junction was removed during that junction's remodelling in the 1980s, the up signal remained long after the track has been removed and was lit (permanently at red, of course).
Shrimper
14 Apr 2012
Skelton Junction has a few on the loops and the Glazebrook line.
There is a shunt signal for a disconnected siding in the vicinity of Northwich too.
Between Hyde North and Guide Bridge you can also see the remnants of some former semaphore signals for the removed lines in the overgrowth.
Thebaz
24 Nov 2016
Purley
Yes, I see them every day and they're still showing red! I wonder how much money has been wasted keeping them illuminated since Network rail severed the siding there? Must have been a good ten years ago.
Crossover
4 Jun 2009
One of them is still there, albeit no longer lit and very very battered last time I saw it!
Removing the signals requires re-doing the interlocking. It is fairly likely, I would have thought, that the controlling box still "thinks" all the junctions are still there, despite being plain-lined. Of course, signals generally have proving circuits so the signals need to display a danger aspect at all times. If they stop working, it would impact on any other line nearby that relied on that being the case
GW43125
8 Dec 2014
How long did the track and signalling remain in situ on the long-gone Down Goods at Stapleford & Sandiacre?
GW43125
8 Dec 2014
The old lines to Curzon St still have the junction signals. Though I'm told these are to go in the resignalling.
JonathanP
1 Aug 2008
Berlin, Germany
I've always found it amusing that there's still a working red signal facing the level crossing at Weymouth where the Quay branch comes in.
Faithfully protecting the Weymouth station area with it's red aspect, day and night, for the past 18 years, waiting for the train which will never come.
mr_moo
7 Sep 2009
Cambridgeshire
The former branch from Seaton Junction to Seaton, now the Seaton tramway, still has some semaphore posts in place, albeit minus arms and very rusty. I use the trams at least once a year (I have relatives in that area) and always think it would be lovely to see them restored.
Dr_Paul
3 Sep 2013
There's not much point having signals on a bike-way, most cyclists would just ignore them.
Dr_Paul
3 Sep 2013
I think it's gone now, but the starter signal on platform 1 at Twickenham for many years showed a red light after the connection to the up slow had been dismantled and the track itself was quite unusable.
RichmondCommu
23 Feb 2010
Richmond, London
I'm pretty certain that there is a semaphore signal at Middleton Top on the Cromford and High Peak trail although its some years since I was last up there.
Harbornite
7 May 2016
Other examples I can think of are the the level crossing lights on the Cambrian line near Oswestry and the signal guarding the short branch leading to the now lifted Albion oil sidings, although this is pushing it.
Parallel
9 Dec 2013
Is it this one? http://stevestrainpics.weebly.com/uploads/6/9/0/5/6905506/1238474_orig.jpg?684
NB: Not my picture
If so a stub of the Weymouth Quay line can be used to stable diesel stock I believe.
