Trivia: Longest end to end service with an inter-peak frequency of every 15 minutes or better
GordonT
26 May 2018
Just like Swindon, the services don't terminate at Leicester, so it doesn't qualify.
Although the Swindon and Leicester examples fall outwith my OP criteria in relation to terminals, they are quite impressive for regularity of high frequency and relatively consistent stopping pattern over substantial distances. Perhaps it's my criteria that's flawed.
Magdalia
1 Jan 2022
The Fens
London to Leicester - 98 miles or so - almost same stopping patterns, just two variations. 4 trains per hour.
Liverpool Street-Stansted Airport only falls down on the standard stopping pattern. All trains call at Tottenham Hale but alternate trains call at Harlow Town or Bishops Stortford, and one train per hour calls at Stansted Mountfitchet.
Haywain
3 Feb 2013
London to Leicester may be 4 tph but it certainly isn't every 15 minutes. If you are relaxingvthe stopping pattern and final destination criteria, then I would suggest that Bedford to London Bridge (and possibly East Croydon) is a good candidate.
Purple Train
16 Jul 2022
Despond
Are there any Thameslink routes that have four trains per hour? I can't think of any since the upgrade, but maybe one of the shorter ones (which may still be in with a shout)?
Not end to end. Hitchin to East Croydon, Bedford to East Croydon and St Albans to Streatham are all four even trains per hour, bar the call at West Hampstead Thameslink in the Bedford to Brighton but not the Bedford to Three Bridges, but no end to end 4tph service.
Magdalia
1 Jan 2022
The Fens
The St Albans-Sutton service probably comes nearest. It is every 15 minutes St Albans-Streatham but then trains go alternately clockwise or anti-clockwise round the Sutton/Wimbledon loop.
GordonT
26 May 2018
Happy to relax the criteria to bring more such services as you suggest into the frame.
PGAT
13 Apr 2022
Selhurst
London Victoria to East Croydon is 9tph off-peak with the same stopping pattern if the final destination criteria is relaxed
fkofilee
19 Jul 2015
While it doesnt fit your criteria - I would consider Thameslink services from Gatwick to Bedford as a contender. Mostly as some terminate at Three Bridges and Others Brighton etc.
cle
17 Nov 2010
Old Thameslink (4tph Bedford-Brighton) was a solid contender, admittedly with some stopping patterns differing, but the core route and key stations were the same.
Southend Victoria is almost there, and 4tph was spoken of for a time. Same with the GN routes (pre-Covid) - fairly standard patterns and destinations, not much branching anyway.
FenMan
13 Oct 2011
Wasn't Waterloo - Reading 4tph for a short period before COVID put its oar in?
py_megapixel
5 Nov 2018
Northern England
Will there be 4tph from London to Birmingham Curzon Street when HS2 first opens? I've lost track of what the proposed service pattern is now, but if so, that will surely wipe the floor with almost anything else.
I think at one point there was a proposal to increase London-Manchester to 4tph, but nothing ever came of it.
Kite159
27 Jan 2014
West of Andover
I believe 4tph was talked about for Southend Victoria before Covid arrived on the scene knocking that on the head, even 3tph there is a different as 1tph calls at Romford (off-peak)
Some of the GN routes when they were running 4tph on both 'branches' had different calling pattern from memory, I want to say some of the quieter stations only had 2tph (off-peak)
Sunil_P
31 Oct 2022
Ilford
Not sure why Underground is excluded when Trams and other Light Rail are included, but for what it's worth West Ruislip to Epping is 34 miles.
GordonT
26 May 2018
I’m guessing because the Underground would win and it would be a short thread.
Yes that's precisely the reason I excluded LU. My interest was more to establish examples of LU-style regularity and its outer suburban frequencies extending over even greater distances and the responses have been very interesting.
