Trivia: Railway lines in other countries with more than four tracks.
busestrains
9 Sep 2022
Salisbury
In the UK we have at least five lines which have more than four tracks:
• 6 Track - Finsbury Park to Alexandra Palace
• 6 Track - Finchley Road to Harrow On The Hill
• 6 Track - London Euston to Watford Junction
• 6 Track - London St Pancras to Mill Hill Broadway
• 8 Track - London Waterloo to Clapham Junction
My question is are there any lines in other countries anywhere around the world with more than four tracks? I would be interested to hear of any examples of other lines like this around the world?
Also i am not counting short little sections outside of stations. I know lots of stations have a short section of more than four tracks as you approach the station. So it must be a proper length section of line with more than four tracks.
U-Bahnfreund
6 Feb 2015
Germany
In Germany, officially each line has 2 tracks maximum, but of course there are places where there are several lines next to each other. I'm thinking right now of the section between Düsseldorf Hbf and Düsseldorf Flughafen, which has six tracks plus sidings.
Shimbleshanks
2 Jan 2012
Purley
The UK also has five tracks between East Croydon and South Croydon.
What about the section between Brussels Midi and Nord? - from memory that is six or maybe more.
Taunton
1 Aug 2013
Sydney Central to Strathfield, the main western approach, 6 track. First couple of miles out to beyond Redfern is 8 track. May be the only one in the Southern Hemisphere.
Beebman
17 Feb 2011
Melbourne, Australia (which I visited last month) has 12 tracks over a 1.5 km distance from Flinders Street Station to Richmond Junction, then 10 from there for another km to Richmond Station. There's a good aerial view of the tracks threading their way between the Melbourne Cricket Ground and the Rod Laver Arena (home of the Australian Open Tennis) at the following link (Flinders Street is visible at the top):
https://www.gettyimages.co.uk/detai...-arena-melbourne-royalty-free-image/128098503
Track plan (scroll down halfway down the page): https://vicsig.net/infrastructure/line/lilydale
Railsigns
15 Feb 2010
Cape Town to Salt River (approx. 4 km) has a minimum of six tracks.
Bemined
28 May 2022
Rotterdam, Netherlands
Rotterdam Stadion - Kijfhoek is pretty wide, although the number of tracks changes all the time so it's hard to count how many there are exactly. The longest continuous section would be the Barendrecht tunnel with 9 tracks that run parallel for about 3 kilometres until they split, the 2 high speed line tracks diverse then and the 3 freight train tracks split up into the big train yard but there are 2 continuous tracks for non-stopping freight trains. So I would say that there are at least 6 through tracks over an 11km distance here, which is extended to 9 through tracks for 3 kilometres.
DanielB
27 Feb 2020
Amersfoort, NL
Utrecht Central to Utrecht Vaartsche Rijn has 8 tracks, though those actually are four sets of two tracks running side by side. The Sprinter and IC corridors towards Arnhem and 's-Hertogenbosch run parallel there, but are essentially running as separate lines with limited connections between them.
Something similar between Amsterdam Muiderpoort and Amsterdam Central where the six tracks are three sets of two running parallel (2 from Utrecht, 2 from Weesp and 2 from Watergraafsmeer yard).
3 Sep 2020
Dublin
In Paris:
Gare de Lyon to Le Vert-de-Maisons, 6 tracks for about 8 km
Gare St-Lazare to Asnières-sur-Seine, 10 tracks for about 4 km
Gare du Nord to St.-Denis, 5 tracks (I think) for about 6 km
Gare de l'Est to Noisy-le-Sec, 6 tracks for about 9 km
I believe Zürich has about 5 km of 5 or more tracks from Hbf out to near Mülligen, but it's possible that not all of these are running lines.
eddp
5 Aug 2011
Berlin
Depending on exactly how you are defining this, there are six tracks between Madrid-Atocha and Madrid-Chamartín:
  • Two Iberian-gauge on the original Túnel de la Risa via Recoletos
  • Two Iberian-gauge on the newer Túnel de la Risa via Sol
  • Two standard-gauge on the recently-opened high speed line (no intermediate stations)
And for another "stretching the definition" example in Spain, outside Barcelona-Sants for about 800m (does this count as "a short stretch outside a station"?) there are six tracks, all Iberian-gauge: two for the Adif line via L'Hospitalet, two for the Adif line via Bellvitge and two for Barcelona metro line L1 (there are also two standard gauge tracks but I think it's pushing it a bit far to count those here). There used to be an additional track for the Airport shuttle but with the building of the high-speed line the previous 5-track railway was reduced to 4 and the airport shuttle moved to the "normal" Bellvitge tracks.
Austriantrain
13 Aug 2018
In Vienna, between Hauptbahnhof and Meidling six tracks. In reality, there are several tracks more, but those are part of the depot.
30907
Working to a more precise definition that the section must have 2 or more stations (not necessarily with platforms on all tracks) :
Germany: Koeln Hansaring-Hbf-Messe/Deutz is 8 then 6.
Zürich Hbf has more than 4 running lines out to ZH-Altstetten.
St Pancras-Mill Hill should be West Hampstead to Silkstream Jn only (5-6).
London Br-New Cross would be 5 as would (stretching a point or two) Victoria to Clapham High St.
I've used OpenRailwayMap to check stuff - very useful.
etr221
10 Mar 2018
The other thing to clarify is what is meant by 'line' - what is the difference between one (multi track) line, and two (fewer track) lines alongside each other?
So - going back to the initial examples quoted - I would classify Finchley Road - Harrow-on-the-Hill as two lines (one LUL, ex Metropolitan Rly [and arguably South of Wembley Park the Jubilee and Met lines are now separate lines, as (AIUI) they can no longer be used interchangeably] , the other NR, ex LNER/GCR), also I would regard the Watford New/DC line as being separate from the ex LNWR main lines (with AC electrification).
D6130
12 Jan 2021
West Yorkshire/Tuscany
In Italy, Roma Bivio Portinaccio-Roma Tiburtina-Roma Smistamento Yard (South end) - six or eight tracks (approximately 7 km).
Roma Ostiense Bivio Est-Roma Trastevere - six tracks (approximately 2 km).
Bologna Bivio Santa Viola (junction for Poretta Terme)-Bologna Centrale East End - at least six tracks (approximately 3 km).
Firenze Santa Maria Novella-Firenze Rifredi (junction for Pisa line) - five or six tracks (approximately 3.5 km)
Milano Certosa-Rho Fiera (junction with high speed line) - six tracks (approximately 6 km).
Bivio Trecca-Milano Rogoredo-Bivio San Donato - six or eight tracks (approximately 6 km).
Milano Bivio Lambro-Segrate - six tracks (approximately 4 km).
Torino Porta Nuova-Torino Lingotto - six or eight tracks (approximately 4.5 km).
(Acknowledging information from the Scheers & Wall Rail Atlas of Italy and Slovenia)
Springs Branch
7 Nov 2013
The Long Island Rail Road in New York has a couple of its busiest sections in Queens with 6 running lines in parallel:-
  • From Winfield Junction (where two tracks from the Port Washington branch join the 4-track LIRR main line west of Jamaica), through Woodside station to the East River Tunnel portals. Four tracks go under the East River to NY Penn, two tracks continue to Long Island City.
  • Eastwards from Jamaica for a distance until the two track West Hempstead / Babylon lines diverge from the 4-track main line near the LIRR Hillside Maintenance Facility.
In the UK list, there's also:- 6 Track - London Liverpool Street to Bethnal Green.
Surely there must be some examples in Japan, particularly Tokyo / Osaka?
Tester
5 Jul 2020
Watford
  • From Winfield Junction (where two tracks from the Port Washington branch join the 4-track LIRR main line west of Jamaica), through Woodside station to the East River Tunnel portal. Four tracks go under the East River to NY Penn, two tracks continue to Long Island City.
  • Eastwards from Jamaica for a distance until the two track West Hempstead / Babylon lines diverge from the 4-track main line.
Too numerous to mention in Japan!
One memorable section for me was through Tsurumi in the Tokyo suburbs, with a level crossing over eleven tracks. When I was working there in 2005 and 2006 I spent many an evening watching the action and counting the number of trains between road openings. Mind bogglingly amazing!
Link to track plan
The level crossing is closed now - hardly a surprise!
Northumbriana
9 Dec 2022
Northumberland
In Paris:
Aren't there 14 tracks out of Paris Gare du Nord? I wonder where they all go?
Six into Gare de Lyon from where the newer LGV merges. Eight from Est?
rf_ioliver
17 Apr 2011
Helsinki-Pasila has 11, after that it splits to 2 4-track sections east and north with lines to the Pasila depot
Käpylä-Oulunkylä is 5 tracks as is Tikkurila-Hiekaharju briefly
Savio-Kerava is also 5 tracks
I guess the 5 track sections are pushing your criteria a bit maybe...
XAM2175
8 Jun 2016
From Richmond, six of those 10 tracks then run for another 1.6 km to South Yarra.
3 Sep 2020
Dublin
The SNCF map I was working from (2017) has eight out of Nord, splitting into five towards St.-Denis and four towards Mitry-Claye. However, I noticed that the most recent version of the map (https://www.sncf-reseau.com/sites/default/files/2020-06/CARTE RFN 2020_WEB_0.pdf) has six, splitting into six and five. A quick look at OpenRailMap suggests there are actually at least 13 running lines from the station to the divergence.
The SNCF map has six from Est to Noisy-le-Sec, but ORM suggests at least seven.
Gostav
14 May 2016
Link to track plan
This video about JR route history shows the multiple track sections in the Tokyo wards.
3 Sep 2020
Dublin
Also in the New York region, the Northeast Corridor has six from south of Elizabeth, NJ (I think the precise spot may be known as Elmora Interlocking), for about 8 km through Linden and Rahway stations to Perth Amboy Junction.
MarcVD
23 Aug 2016
In Belgium, there are also 6 tracks between Antwerpen Berchem and Antwerpen Central. With the very unique peculiarity that they all start from the same level at Antwerpen Berchem, but end up at 3 different levels in Antwerpen Central. 2 of them continue further north, the 4 others terminate in Central.Screenshot_20221216-234941_Samsung Notes.jpg
I believe there are also 6 tracks in Germany between Köln Hbf and Köln Deutz, notably on the bridge over the Rhine River, that also has a foot/cycle path which offers a very good view on the constant parade of trains going over there...
Northumbriana
9 Dec 2022
Northumberland
In Belgium, there are also 6 tracks between Antwerpen Berchem and Antwerpen Central. With the very unique peculiarity that they all start from the same level at Antwerpen Berchem, but end up at 3 different levels in Antwerpen Central. 2 of them continue further north, the 4 others terminate in Central.View attachment 125391
What website is that from please?
dutchflyer
17 Oct 2013
Thailand, Malaysia, Indonesia, Vietnam, Myanmar, Phillippines does not have any, nor probably the newly built line in Laos.
In NL there are as such 6 tracks (quite a rarity in this country) between Amsterdam CS and Sloterdijk, but effectively 3x2 for the lines to Haarlem and Zaan and north of that toward Schiphol, which crosses and sits above the 2 others at Sloterdijk.
Schiphol-Hoofddorp may have it, but then 2 are more for the trains going to the yards just south of H´drp. Not really sure about that.
Also -but just from memory, perhaps a short stretch south of Utrecht CS till Vaartse Rijn-2 for the Arnhem line and 4 on the line south toward den Bosch.
stuu
2 Sep 2011
In Thailand the section from Bang Sue to Don Muang has 6 tracks, with 4 elevated and 2 at ground level.
