TRUST Points
ComUtoR
13 Dec 2013
Morning, Evening, or Afternoon.
Is there track-side equipment for a TRUST point or is it based on the track circuit berth ?
How does TRUST know when a train has arrived etc ? Is there some interpretation of the data, as it it trips trust but then a minute or so is added for a unit actually arriving at a station. It takes almost 2 minutes to hit the buffers some times but a service will show arrived before its even hit the platform.
Cheers in advance.
Llanigraham
23 Mar 2013
Powys
Depends where you are. Many "reporting points" are still manual ones, with the signaller entering the times as the train passes the Box.
Poggs
28 Aug 2008
Is there track-side equipment for a TRUST point or is it based on the track circuit berth?
There's nothing TRUST-specific trackside. TRUST uses TD berth data where the train describer reports to a system called SMART.
How does TRUST know when a train has arrived etc? Is there some interpretation of the data, as it it trips trust but then a minute or so is added for a unit actually arriving at a station. It takes almost 2 minutes to hit the buffers some times but a service will show arrived before its even hit the platform.
TRUST works off berth operations, as well as GPS movement reports and manual inputs.
For an auto-reporting point, the TRUST arrival or departure will be based on the time the train's description stepped between two berths (or in some cases, was interposed in, or cancelled from, a berth), plus or minus an berth offset. This is what causes an arrival at a terminus to appear on TRUST before the train's come to a stop - the arrival time is taken as, for example, +60 seconds from the time it passes the last signal before the platform.
There is a spreadsheet of all the berth moves (interpose, step or cancel), and the events they relate to, with berth offsets and STANOXes. I can upload a copy here if you're interested.
For a manual reporting point, it relies on a signaller, IM or RU staff entering the arrival or departure time manually in to TRUST. This can't be done in advance - you can't report a train as having arrived at 1205 if the time's 1204 - but you can report a train as having arrived at 1205 if it's 1206 or later.
GPS is different and I won't go in to the detail here.
ComUtoR
13 Dec 2013
You're stars, many many thanks.
