Tyne & Wear Metro Fleet Replacement: Awarded to Stadler
David2210
24 Mar 2018
Sorry for the bit off topic question, but why do some of the metros now sound like "tube" trains, they have a high pitched coil whining sound when accelerating.
100andthirty
Milton Keynes
Generally, they make "coil whining" sounds because they have large could underneath and are producing variable frequency ac power for the traction motors. Siemens, Bombardier, and Alstom's trains all sound a bit different, but all have the whine or buzz
hacman
22 Jul 2011
No. These trains have DC motors.
The noise here is caused by the track. Explanation posted in the other TW Metro thread.
hacman
22 Jul 2011
Yes. I answered regarding TW Metro stock, as that is what the OP here asked about, and it’s in the TW Metro thread.
jkkne
13 Aug 2012
I’m guessing the hangover from the Beast from the East and general maintenance is continuing.
There’s been very few peak trains running of late, it’s been sardine esque on the Cosst to Shields the past few weeks.
Perhaps Easter will provide a reprieve!
ModernRailways
21 Apr 2011
We've been running for a while now with 2-4 peak trains missing - I've noticed complaints about this have risen in recent weeks though (any idea why?). We're short on units so anything that is able to be put into passenger service is. It's the reason 4002 is still out in day-to-day service.
Don't get your hopes up ;)
Jonny
10 Feb 2011
Like David2210, I've noticed a high pitched, motor-like sound when on the Metro recently and I was wondering what would cause it (sounds like it's from the train).
I haven't been able to find that explanation. Do you have a link?
ModernRailways
21 Apr 2011
If you listen closely you'll hear it's the rail and not the train. Here's the Quote from the other thread, if you click the little up arrow that will take you to the thread/post.
This isn’t the trains, it’s the rails.
Rail grinding has been done south of Ilford Road to at least as far as Central Station.
The freshly ground rails have striations on the railhead, which is what causes the F1 car / old tube train sound.
DanNCL
17 Jul 2017
County Durham
I've heard that 4022 may now have been scrapped. Is anyone able to confirm whether it has been scrapped or not, and if it has been scrapped where and when it was scrapped?
ModernRailways
21 Apr 2011
4040 is the only one of the unrefurbished sets that I've not had this year. Unfortunately I won't be able to catch it today, any idea if it'll be out on Monday?
It's been in service for the past couple weeks so yes, obviously this can be subject to last minute change on the morning.
DanNCL
17 Jul 2017
County Durham
4040 and 4001 are out on Airport - South Hylton services on diagram 102 today if anyone's interested
EDIT: both unrefurbished sets are out today; 4002 and 4083 are on peak extras
ModernRailways
21 Apr 2011
There's five shortlisted. CAF, Bombardier, Stadler, Hitachi, and a joint venture between CRRC and Edi Rail. Chris Grayling is up at the depot and will be announcing it all there.
MetroCar4058
18 Jun 2014
Interesting to see CAF proposing their Civity platform is where they’re going to start. When having a read they already offer a 1500V DC package on the Class 331 which may be handy as a starting point.
Mikey C
11 Feb 2013
I assume Bombardier's offering will be a Movia derivative like the Underground S stock rather than an Aventra?
I should think almost any supplier’s AC traction package should be easily adaptable to take a 1500V input. It’s within the same ballpark as the DC link stage of a typical AC OHLE supplied unit.
zuriblue
12 Oct 2014
Baden Switzerland
Certainly most of the shortlisted suppliers have recently supplied stock to the Netherlands which is at 1500V.
CAF's traction package is probably descended from a Spanish one where they use 3kV on their conventional network.
Skymonster
7 Feb 2012
Nope - picture of it dated 15/09 under a tarp at Bristol Barton Hill on the WNXX news page.
hacman
22 Jul 2011
The new fleet is required to be dual voltage 1500V DC / 25kV AC too, so regardless which platform was chosen for traction there would be a voltage/type conversion capability.
The traction package would likely be an AC system anyway, as that is the current way of doing things.
18 Jul 2013
Preferred supplier not being announced until end of next year though, seems rather protracted.
hacman
22 Jul 2011
They need to actually propose a basic design before Nexus can select one as the preferred option!
As the order will not be an off-shelf design, and has quite a tight budget, this will take time.
superkev
1 Mar 2015
west yorkshire
Tram Train operation? Presumably the T and W metro uses standard rail rather than thinner tram flange wheels. So is it a train or a tram.
The SY tram train has thin flange tram wheels needing raised check rails on the Network rail section.
Also is there special rules on operation of light rail between Pelaw and Sunderland.
K
hacman
22 Jul 2011
K
They’re trains. The current stock uses a British Rail P8 wheel profile.
The Sunderland line doesn’t really have much in the way of special rules. The main differences are the dual (metric and imperial) speed restrictions and the requirement for more space between services owing to the fact that the line uses both TPWS and indusi signaling.
