Via Ely costs more than Any Permitted
Brucey
7 Jan 2010
Looking at Waterbeach [WBC] to Peterborough [PBO] with a railcard.
Any Permitted Anytime Day Return £11.10 (set by EMT)
Via Ely Anytime Day Return £13.05 (set by AGA)
Waterbeach is a member of Cambridge and Ely routeing groups, so the cheaper any permitted fare would surely be valid via Ely anyway.
Can anyone suggest why the higher fare may exist? Surely no-one would buy it?
greatkingrat
20 Jan 2011
And to make it even more confusing, there are also "Not Via London" fares set by VTEC, which are presumably intended to allow travel via Stevenage, but according to the Routeing Guide are only valid via Ely as well!
Romilly
5 Nov 2013
So far as I can see, the routeing guide allows Waterbeach to Peterborough either via Ely or via Hitchin. Both Cambridge and Ely are valid routeing points for Waterbeach for a Waterbeach-Peterborough journey (Peterborough is a routeing point), and Cambridge to Peterborough is permitted via Hitchin as well as via Ely.
greatkingrat
20 Jan 2011
It is an odd one, because there is no Any Permitted ticket from Cambridge. The SDS prices are from Waterbeach 16.50 via Ely and 15.50 Any Permitted, and from Cambridge 16.50 via Ely.
So Cambridge only passes the fares rule if you have the Via Ely ticket, which means you can't go via Stevenage, NRE also says you need two tickets for that route.
kieron
22 Mar 2012
Connah's Quay
Just to say, a Waterbeach-Peterborough "any permitted" ticket passes the fare check for Cambridge (or Ely) because ATOC's routeing point calculator says it does.
The maps mean that it's valid via Cambridge and Hitchin.
Easement 700070 says "Customers travelling from stations North of Cheshunt via Cambridge and Hitchin to stations North of Hitchin may double back between Hitchin and Stevenage. This easement applies in both directions." This means that it's valid via Cambridge and Stevenage.
I don't think a "via Ely" ticket gives any extra validity.
amateur
23 Feb 2014
Presumably, someone could go waterbeach to Cambridge, and then Cambridge to Peterborough on the XC
kieron
22 Mar 2012
Connah's Quay
They can, and they can also be used with "any permitted" tickets. Cambridge-Ely-Peterborough is a valid route from Cambridge to Peterborough. It isn't "a route not listed in the Routeing Guide for which a higher priced route specific fare exists".
